What is "normal" for a compression check?
Old Mar 30, 2010 | 09:26 PM
Krenshar's Avatar
Default What is "normal" for a compression check?
Hey all. I just had a leak-down and compression check done on my 2002 A6 3.0 Quattro. The compression test results (with 3 different gauges) were 115-120 across all 6 cylinders and the leak-down showed four at 10% and two at 15% (not bad if you read my other post). I found one place that said the compression test should be 145, but haven't been able to confirm that. Based on what I've read about the leak-down test, my results are good (anything above 20% is bad).
Does anyone know what a normal/good compression test should be for my car?
Thanks!
