Where's the Engine Coolant Drain Plug?
Old Jan 2, 2008 | 12:41 PM
ne2q 73's Avatar
Default Where's the Engine Coolant Drain Plug?
On a 1995, A6. 2.8L Quattro. Anyone know where the Engine Coolant Drain Plug is located exactly? I see a drawing [ 10-1170 ] on page B 19-9 of Bentley Volume #1 but the drawing is not clear enough for me to locate this plug. They refer to using special tool 3247 to remove the plug.
I want to replace coolant. After draining the radiator by opening the Radiator drain, I only was able to get only 4 litres of coolant to drain out. Yes I measured it. The system calls for 8 litre capacity so obviously 50% of the coolant is still trapped in the engine cooling passages. I would think opening this so called Engine Drain Plug will allow the rest to come out.
Blowing into the expansion tank with the radiator drain plug open got just a few ounces additional out.
Any idea how to get the balance of the old coolant out other than finding this Engine Coolant Drain Plug and opening it?
Old Jan 2, 2008 | 06:02 PM
ne2q 73's Avatar
Default RE: Where's the Engine Coolant Drain Plug?
After more searching I did find the Engine coolant Drain plug and removed it. I used an 8mm allen head on a universal joint socket adapter to unscrew it.
The O-Ring that fits around the plug was torn. It feels soft and pliable enough to be a silicone O-Ring.
I am now wondering if a standard rubber O-ring would be suitable for a replacement or is a Silicone O-ring required because of temperatures over 200F ?
Thanks for any input on this.
Pbcrazy
Oct 10, 2012 06:35 PM
PacificA4
May 16, 2012 07:53 AM
jaybird
Oct 15, 2010 03:48 PM
jmatthias
Oct 9, 2008 11:01 PM
Agnt008
Feb 29, 2008 02:43 AM
