Sponsored by:
Sponsored by:
White Smoke
Old 04-28-2008, 10:24 PM
nfong2684's Avatar
Default White Smoke
Hows it going guys...had a quick question
I have a 99 Audi A6 Avant 2.8L, Been noticing that as i drive there is white smoke that seems to eminate from under my engine. As i drive it seems to get worse...ie...if i drive for say 1/2 an hour there is more smoke than if i drive a few minutes. They are not like huge plumes of smoke, but it does smoke to the point where it is quite visible. If it does help any i did recently get my motor mounts replaced. Any info would be greatly appreciated!
Regards,
Nick
Old 04-28-2008, 10:27 PM
gottwinns's Avatar
Default RE: White Smoke
your either burning oil or its something else
Old 04-28-2008, 10:38 PM
nfong2684's Avatar
did alil forum scanning seems that it might be the cam or valve seals...am i correct in this assumption?
Old 04-29-2008, 08:23 AM
bob martin's Avatar
No way we can really tell with the information provided, but that would be a good place to look.
Good luck!
Bob
Old 04-29-2008, 11:57 PM
Wayne.L's Avatar
coolent leak?
Old 04-30-2008, 12:02 AM
kerosene's Avatar
under the engine - not exhaust I assume. If it was valve seals leaking oil into the intake the smoke would come out from the exhaust (and most likely be more smokey right after you start engine after it has been sitting)
The best advice would be to try to trace the actual source location more accurately.
cjcraw22
04-01-2016 03:32 PM
charliejamie
02-19-2015 01:16 AM
ilovemyaudia4
B7 Models
06-03-2011 06:59 PM
shazoo
B8 Models
06-16-2010 07:35 AM
Quick Reply: White Smoke
