Why is my car shaking?
Old May 22, 2013 | 09:04 AM
BostonSims's Avatar
Originally Posted by Nebuchadnezzar
Your p300 code maybe related to a bad ICM. With that amount of miles on it, I'm willing to bet they are the original ones, and they are probably on their way out. When they go bad they will wreak all kinds of havoc on your firing sequence and overall performance.
You should find two ICM units either on top of your air filter box or very close to it. Swap them around and see if the issue goes to another cylinder. Of course, you will only know this if you have a VAG-COM.
Here is a link to how much they cost and what they look like:
Audi C5 A6 Quattro 2.7T > Search > Ignition Control > ES#10206 Ignition Control Module - Priced Each - 4A0905351A
i second that. I had random misfires like crazy back in 2011 and independent shops were saying one thing, the audi dealer was saying another. The quotes were from $1,500-2,000. Then i learned how temperamental the icms are and decided to investigate that. It turned out when i washed my engine bay i washed all the dielectric grease from in between the icms and the airbox. I cleaned the box and icm with electronic parts cleaner, added a clean glob of dielectric grease ($5 at most places) and started my car. Never had a problem since. Everyone was ready to replace all these parts on my car and the culprit was $5 worth of grease. Check it out bro before anything else. The grease is important because it absorbs all the heat from the icms and dissipates it into the airbox.
Old May 22, 2013 | 10:31 AM
ECS Tuning's Avatar
Sponsor
X3 Thanks for posting the link!
Jason
Old Jun 2, 2013 | 01:03 PM
CDCastro's Avatar
Sent my car to the shop. I replaced all coil packs and replaced leaking vacuum pipes. It totaled to $540. I will let you know if my car is running fine again or if the problems still occur.
Old Apr 22, 2014 | 08:09 PM
blankley30's Avatar
Default Bad ICM
How can you test to see if the ICM is bad?
Thanks
Old May 4, 2014 | 10:27 PM
BostonSims's Avatar
if an entire bank is misfiring, or non-grouped cylinders. so if banks 1-4 are all misfiring at the same time, or you have multiple misfires randomly from all the cylinders. i would read codes and different cylinders were misfiring randomly. As i said before i thought it was the ignition coils at first but before replacing them i ended up sourcing the problem to my icms and noticed they were missing the electrostatic grease.
Sross03
Jun 28, 2011 02:45 PM
edepaolo
Jun 13, 2010 09:24 PM
jmarinac
May 4, 2010 09:00 AM
marcus02390
Apr 20, 2009 01:14 AM
antonio
Aug 26, 2008 11:06 AM
