wind noise from driver window
Old May 3, 2007 | 04:29 PM
auditech79's Avatar
Default RE: wind noise from driver window
Wind noises can fool you, they can enter at one point and you might hear it at another, but if the foam insert is there you can adjust the door by simply grabbing the top of the window frame and pulling it as hard as you can towards the car, its primative but it works.
Old May 3, 2007 | 10:21 PM
ppgoal's Avatar
I'll be interested how all this turns out. I've noticed wind noise towards the toprear of my driver's front window since I bought the car two years (and 62k) miles ago. I think it's just not pressing against the top seal enough. I was going to try and finda thin felt seal and glue it into that corner, then see if the window compresses it and the noise goes away. I've been traveling every week and have not had time to get around to it.
Old May 3, 2007 | 11:53 PM
SLINEA6's Avatar
thanks for everyones help, i will let you know what happens..
Old May 23, 2007 | 11:49 AM
SLINEA6's Avatar
So I think I fixed my issue, I found it on Audi world but i forgot to get the link up, it was different fix from what the tech article on there. The guy put the same kind of tubing in between the vinyl on the inside of the door at the top, (in that little valley)so I did that with the tubing left over from my fish tank and man its really quit now, i mean its still slightly there but i think that is my ear wanted to hear something, its nothing like it was, i just put about a foot long tubing in there...it seems to work! I am trying to find that article on Audi world to post it...
Old May 23, 2007 | 11:52 AM
SLINEA6's Avatar
found it!
http://forums.audiworld.com/a4/msgs/2324427.phtml
here is what i did
Old May 23, 2007 | 11:53 AM
techbod's Avatar
with a drag coefficient of less than 0.28 anything will make that noise so consider this
http://images.google.co.uk/images?gb...or&spell=1
Old May 23, 2007 | 11:57 AM
SLINEA6's Avatar
yeah, never had those wind deflectors before, what is a drag coefficient of less than 0.28 mean?
Old May 23, 2007 | 12:03 PM
  #18
techbod's Avatar
put it this way ( open your windows ) then feel the resistance and the noise, the drag coefficient is tested In a wind tunnel so really means nothing unless your on the the track and speed is the point
Old May 24, 2007 | 07:52 PM
  #19
ppgoal's Avatar
SLINEA6 - Thanks for the tech article. I'm going to try the airhose trick this weekend. I just hope my goldfish doesn't suffocate.
Old May 25, 2007 | 02:21 PM
  #20
SLINEA6's Avatar
yeah man, i have been doing fish tanks for years i had a bunch laying around good luck!
