Window glass playing notorius
Old Dec 30, 2008 | 09:37 PM
Ajay4u's Avatar
Default Window glass playing notorius
I have a 1999 Audi A6 and a couple of days back the driver side window glass started malfunctioning, when I slide it down, it refuse to come up even if I tries continuosly. looks as if something is dragging it downwards. It tries to come up and then slides back down. The back window at the driver's side now also started copying it. Is this a problem with some loose wire or something else.
This behaviour is only at the driver's side front and rear windows. Please suggest what could be the problem.
Old Dec 30, 2008 | 10:56 PM
chefro's Avatar
it sounds like the window regulators... probably more specifically the plastic guides are broken.
you may want to check out the following articles, although only one is for A6
(the procedure should be somewhat similar for all the models, despite maybe a different design in taking apart the door panel) :
--- Window Regulator Replacement - A4, S4
--- Window Plastic Guides Replacement - A6
Rn3037
Feb 1, 2012 08:20 PM
a4ever4a
B7 Models
Dec 28, 2009 01:19 AM
wantonsoup
Nov 28, 2007 05:08 PM
preyash
Oct 29, 2006 11:16 PM
graymarki
Jan 6, 2006 01:53 PM
