windshield wash fluid - running out frequently
Old Aug 8, 2007 | 10:04 PM
sarthak's Avatar
Default windshield wash fluid - running out frequently
I filled windshield wash fluid in my Audi A6 3.0 to the neck. But it ran out in just 4 days, where I have not used it at all. Obviously there is some kind of leakage, but can it be so that there is a draining facility which is left open during a recent service?
Old Aug 9, 2007 | 10:34 AM
madridlover's Avatar
Default RE: windshield wash fluid - running out frequently
You probably have a bad o-ring somewhere in the system or a hole in one or more of the tubing. Very common on these cars.
Old Aug 9, 2007 | 02:35 PM
sarthak's Avatar
Thanks. Is there a way I can repaire myself or need to take to a service center? What amount of expense am I looking at for this?
Old Aug 9, 2007 | 04:53 PM
ppgoal's Avatar
You should be able to get at the unit from the bottom. I would bet the problem is in the plumbing to the headlight washers. I had the same problem and firstreplaced the headlight washerassemblies in the bumpers. It started leaking again. I just bit the bullet and had my shopblock the headlight washer system. If was an easy fix according to them.
The headlight washer system pumps out a huge amount of fluid when you wash your windshield with the lights on.
Old Aug 9, 2007 | 09:38 PM
sarthak's Avatar
Thanks buddy... thanks for taking time in replying.
Old Aug 10, 2007 | 06:30 AM
bob martin's Avatar
I have the same problem. It's the rubber seals around the two pumps. One costs $3, the other less than $2. You have to get to the washer bottle from the wheel well. It's a pain!
Bob
Old Aug 12, 2007 | 11:00 AM
sarthak's Avatar
Thanks Bob. I will give it a try and check how far I get with the fix.
Old Aug 12, 2007 | 05:47 PM
MiniSpdRcr's Avatar
Same problem, but my bottle is actually cracked :X Have to seal it up...but am a bit lazy.
Old Aug 15, 2007 | 04:42 AM
katcoota's Avatar
Like Bob, my leak was down to the rubber washers around the pumps. A bit annoying having to get to it from the wheel liner, but easy enough if you jack the car to get some more space.
I didn't want to remove my wheel...
polyflon
Jan 9, 2014 07:15 PM
stathound
B8 Models
Feb 11, 2009 10:24 AM
ouzo 2
Dec 23, 2008 08:30 PM
Audi311
Dec 11, 2008 07:48 PM
kidpositive
Nov 20, 2005 07:01 PM
