Windshield whiper fluid???
Old Dec 11, 2008 | 04:05 PM
Audi311's Avatar
Default Windshield whiper fluid???
So I got a light on my dash saying I'm low on windhsield whiper fluid. So I go to fill it up and no more than 5 seconds of pouring in the fluid, fluid starts gushing up from underneath the car. I couldn't tell exactly where it was coming from, but now i'm completely confused. The dash light is still on the for the fluid and I can't seem to make it go away.
Any ideas?
Old Dec 11, 2008 | 07:10 PM
Tweaked's Avatar
Do you have headlight washers? Check the hoses and the jets for leaks.
Pull the under pan and poke your head under the LF (driver side) bumper cover. Look for leaks. Common leaks include the hoses and the pump gasket.
Old Dec 11, 2008 | 07:48 PM
AutoUnionFan's Avatar
^ +1
hose that runs from reservoir to headlights is actually two pieces. I had a similar problem with my car, for some reason when I used the windshield wipers, pressure would build up in the lines forcing the connection to break. If this is the problem that you have, make sure you connect the hoses properly and lock it in place. also shoot some fluid on the windshield to test before you reassemble everything
or it could be a broken reservoir, fairly common on some models,
take off the wheel well cover to get a better look, if i remember correctly
polyflon
Jan 9, 2014 07:15 PM
zzr
Nov 17, 2009 08:38 AM
stathound
B8 Models
Feb 11, 2009 10:24 AM
ouzo 2
Dec 23, 2008 08:30 PM
kidpositive
Nov 20, 2005 07:01 PM
