Windshield washers not working.
Hey guys, So my sprayers are not shooting anything out. Wipers are working, fluid tank is FULL, all fuses are good and the headlight sprayers ARE working. With the headlights off (so they don't spray) I don't hear any type of pump when I use the washer lever. Are there two separate pumps for the headlight washers and the windshield washers and where are they located?
Any ideas/comments are greatly appreciated,
Thanks.
Thanks.
I had trouble with the "plastic" feeding line going into the washers, as it ages and becomes brittle. I was losing the fluid and nothing was coming into the washers.
The lucky thing was that the broken section was in the relay box area, so I was able to see it. The line is mounted via a plastic clamp on the hood, so getting bent (every time when the hood was closed) over time caused the brittle plastic to crack. I replaced quite a long section of the line with rubber hose (vaccum hose works excellent).
In your case, if you don't lose any fluid and you don't hear the pump... IRC, the pump is located directly on the bottom of the washer tank, or on the fender. It sounds like bad pump or bad connector.
Thanks chefro,
I just checked the hose and it isn't brittle at all...I can blow on it and air is coming through just fine. I pulled out the whole washer fluid tank and disconnected everything but the windshield washed motor/pump. The pump clicks really softly when I hit the lever but no air comes out of the spout and the pump makes no other noise accept for the clicks.
So I'm guessing the pump is bad. Do you know how to take the pump out of the tank? I'm afraid I'm going to break it. Also does anyone know a good place to purchase a pump at a decent price?
...'tis good timing to check also on your power steering hoses, at the reservoir.
I would trust any place like Blaufergnugen, Ariz Autohaus, Force5Auto (used ones though), Shokan (used ones), AutopartsWarehouse.com, GermanPartsOnline, FCPGroton, RockAuto, PartsGeek.com, etc, etc.
good luck
good luck
hedman09
Jun 23, 2008 07:38 PM
jaketone
May 26, 2008 01:58 AM
