Washers Not Working
Old Jan 30, 2005 | 11:42 PM
Auditwins's Avatar
Default Washers Not Working
Our windshield washers stopped working. The wipers still work. Washer system is full.
Car is a 2002 A4
Jestnomen's Avatar
6th Gear
Default RE: Washers Not Working
dead washer pump
Old Jan 31, 2005 | 12:28 AM
Auditwins's Avatar
Just read an old post that suggest checking a different fuse. Checked it out. It was the fuse. It appears all is working Switched it with the horn fuse. Now the washer works no horn. Guess it was the fuse.
Old Jan 31, 2005 | 12:36 AM
Jestnomen's Avatar
6th Gear
Well that's an easy fix. If it blows again soon though, you have a problem.
Old Feb 6, 2005 | 12:47 AM
Auditwins's Avatar
Default RE: Washers Not Working Update
Washer fuse popped again. Call the Audi dealer. They said this is a common problem with A4's. They now install 30A fuses in lieu of the 25A suggested in the owner manual. So far it seem to be working.
Any one else been told this? If so, will the 30A fuse do the job without damaging the motor?
Old Feb 6, 2005 | 02:32 AM
flyboy's Avatar
That could work, I don't really like the idea of using a larger fuse, but I also don't know the size or capabilitys of the wiring in the car. The motor shouln't be hurt but as a rule you want the fuse to be the weakest link, not wires or anything else. But If thats what they told you.
Old Feb 6, 2005 | 10:49 AM
david9999's Avatar
If it blows again, search the archives before replacing the motor. The wiper arm mechanisms tend to stiffen/bind with age, and can cause the motor to overheat and blow the fuse.
Old Feb 6, 2005 | 10:57 AM
Auditwins's Avatar
David9999,
Car is not that old. 02 with 30K
The wipers always work. It is the washer pump fuse that shorts out.
Old Feb 6, 2005 | 11:20 AM
david9999's Avatar
Sorry, asleep at the wheel.
Old Feb 6, 2005 | 11:22 AM
Auditwins's Avatar
Just thought you might have another thought
meshkis
May 20, 2014 09:40 AM
Chingon1988
Nov 22, 2010 09:06 AM
Lopster99
Mar 6, 2007 08:03 PM
///A4
Sep 7, 2005 07:50 AM
