Windshield Wipers.. I know..
Old Jan 9, 2010 | 08:39 AM
bob martin's Avatar
Pull back on the cover (away from the arm) and lift the arm off the blade. Dead simple. Make sure to put a small amount of lube on the bar at the end of the arm that nests into the blade. This bar needs to swivel and if it doesn't the blade lifts from the windshield leaving a nice wide streak right in front of your eyes.
Bob
Old Jan 10, 2010 | 05:19 AM
chefro's Avatar
You guys would laugh but... I replaced mine with Pylon blades (same company that manufactures the Michelin ones sold here...LOL) bought at Walmart... I know, I know....I'm feeding the corporate pig...
They were like $ 4/piece and I said to give it a try (I typically use Michelin, but then I saw the manufacturer on them; and they do have the same design as Pylon...).
Needless to say that the "try" became permanent replacement as they're excellent.
I'll let you all buy the $ 30-40 Icons and Aeros.
Old Jan 11, 2010 | 01:57 PM
DtTall's Avatar
Default Missing Spots
Hey All - A little diviation on the topic (let me know if I should just post new).
I have a '02 A6 with factory blades (new from dealer) and the right blade misses the middle section of the wipe as if there isn't enough pressure to keep it against the glass. I thought my old blade was bad (hence I bought new ones) but it has the exact same problem.
Anybody know how to increase pressure on the blade to get it to wipe?
Thanks!
Old Jan 11, 2010 | 02:23 PM
Midniteoyl's Avatar
You prolly dont have enough pressure being exerted by the arm itself. Bend it toward the windshield just a bit.
Old Jan 12, 2010 | 02:43 PM
gahndai's Avatar
"Make sure to put a small amount of lube on the bar at the end of the arm that nests into the blade. This bar needs to swivel and if it doesn't the blade lifts from the windshield leaving a nice wide streak right in front of your eyes."
make sure you lube up as well!
billybod
Jan 30, 2013 09:07 PM
jlight113
Jun 6, 2010 03:23 PM
shelbyturbo
Feb 7, 2008 06:46 PM
01afour
Nov 14, 2007 07:15 PM
01afour
Aug 21, 2007 01:54 PM
