Wiper blades?
Old Apr 10, 2006 | 04:19 PM
slee22's Avatar
Default Wiper blades?
Where can I get some wiper blades for my '02 A6? They don't have anything that will fit at the Parts stores around here. I found some on ECS, but I'm not too sure which ones to get. Thanks
Old Apr 10, 2006 | 04:29 PM
techbod's Avatar
Default RE: Wiper blades?
take one into the garage with you and compare it by size, they should have a multi kit for fitting with them for most cars
Old Apr 10, 2006 | 06:50 PM
4dot's Avatar
i bought some replacement micro blades from auto-zone for $23. they seem to work better than the originals. they won't have them out in the isles though. you have to go up to the guy @ the counter and tell him what kind of car you have so he can pull them from the back.........or at least thats the way it happened for me.
Old Apr 10, 2006 | 11:15 PM
beefski's Avatar
i bought the bosh micro edge at a chain auto parts store, am very satisfied.
Old Apr 11, 2006 | 12:11 AM
DJ_JonnyV's Avatar
Recently put some Bosch Icons on my A6 and they are outstanding. I have an '01 A6 2.8Q and put 422A and 422B on it.
Old Apr 11, 2006 | 02:40 AM
slee22's Avatar
So the Bosch micro edge from here will work?
Thanks for the replies!
Old Apr 18, 2006 | 02:50 AM
choraltech's Avatar
They will fit - trust me. I thought I was going to have to buy from the dealer because the cheapy $3 Anco ones from WalMart wouldn't work, then I tried Bosch from Advance Auto - they didn't work either. I thought it had something to do with the slit opening on the wiper and the long hook of the wiper arm not fitting. I then took off the remaining drivers side one to see how it worked - I can't believe it took me so long to figure it out - they did end up fitting - just push it through at a different angle (more perpendicular to the blade) and then angle back and slide. You will have to use the extra piece of plastic that probably came with the blade.
Old Apr 18, 2006 | 03:45 AM
slee22's Avatar
Thanks
Ace607520
Jul 20, 2010 11:46 PM
wvueer220
Jul 10, 2010 09:19 PM
Newaudilover
Mar 20, 2008 06:13 AM
SouthernAudi
Dec 19, 2007 06:52 PM
PhilH930
Oct 25, 2007 07:44 PM
