Would u recommend this part?
Old Sep 21, 2010 | 02:04 PM
WoodShoe's Avatar
Originally Posted by jackson101
C'mon, spend the 30.00 in parts and rebuild it yourself. Or take it to a local re-builder and keep your dollars at home. There are several alternatives to buying that junk from AZ and AAP.
I agree. Only takes few min to find a local guy to re-build one. I've had to get two of my previous vehicles done. Took it to the same guy both times. Spent 140$CDN both times. Got great service and 2 yrs warranty both times. And never had a problem with either after the rebuild. Support your local guys ...
Old Sep 21, 2010 | 05:11 PM
upallnight's Avatar
Old Sep 21, 2010 | 08:31 PM
ninetynineA6Q's Avatar
Just beware of the law of unintended consequences if your original alternator is a 120-Amp unit.
Old Nov 2, 2010 | 08:38 PM
niknak's Avatar
Originally Posted by Zachariah
Could be just voltage regulator?
That was the problem with my alternator
BTW I own a 1989 100Q and replaced the failed original alternator in 1996 with a rebuilt Bosch...never had a problem since until 3 months ago...symptom was the Ammeter showed not charging, but Alt (BAT) trouble light was not lit up
so I replaced the voltage regulator for $34.00 and the problem was solved (brushes were well worn on old regulator and the Bosch still lives on)!
Old Nov 3, 2010 | 09:23 PM
NorthD's Avatar
Default part
yes the part will be fine. a little heavier but it should be a good bargain i bought one and has been a year o problems
littleA3
May 9, 2014 07:23 AM
amrrashad
Sep 4, 2009 02:42 PM
rrfernan
Feb 22, 2008 08:15 PM
explosionsteve
Dec 18, 2007 04:47 PM
