Xenon's jiggle
Old Feb 25, 2006 | 09:57 AM
aseem's Avatar
Default Xenon's jiggle
Never had Xenons before. Mine jiggle when I hit a big bump. Is that normal or is something loose?
Old Feb 25, 2006 | 01:11 PM
cary12's Avatar
Default RE: Xenon's jiggle
Check to see if your housing is loose. I'm taking mine in for the same problem. I have a broken bracket in mine. A body shop will fix it for close to nothing.
Old Feb 25, 2006 | 03:15 PM
Jestnomen's Avatar
6th Gear
Sure that's not just the autoleveling feature?
Old Mar 3, 2006 | 03:01 AM
Aaron_W's Avatar
I just purchased my first Audi...a 2001 A6 4.2. I also had a bit of a "jiggle" in the Xenon lights. After close inspection, I found that ALL THREE mounting brackets were completely destroyed. The light worked fine, but it was hanging on by not much more than a prayer. Hmmmm....not good.
I used some metal strapping to secure the front side (used very short pieces to construct the brace) and a mending brace to create a mounting bracket on the lower rear side of the light. Now I have a non-jiggler and everyone is happy.
Check the mounting brackets....you may have loose or broken hardware.
Aaron
Old Mar 3, 2006 | 12:36 PM
aseem's Avatar
OK- Thanks Aaron. I'll take a look.
G3ML1NGZ
Aug 8, 2014 09:30 AM
PartsPro0101
Jul 30, 2008 08:22 PM
ejc317
Jun 30, 2006 12:15 AM
gsxr150
Sep 10, 2005 03:31 AM
mrfredo82
May 16, 2005 01:17 AM
