Yellow stuff in Engine oil?????
my 96 A6 Quattro has been popping up with problems and one i noticed was this yellowish stuff in my oil. Its all inside the oil compartment.
What is the problem and what would be the best thing to fix this?????
thanks!
thanks!
Most likely its not a problem, if you make short trips a lot condensation always builds up on the oil cap and dip stick. Its usually normal in cold climates. If when you drain the oil and you can visually see yellow in the drain pan then you might have a problem, but a little is ok.
oh ok. Thanks cause i do make a lot of short trips and i do live in New England. So its definitely cold right now. I also did my oil recently and didnt see it in the drain pan. So i think im safe. Thank you though!!!
pzp107
Mar 19, 2012 03:51 PM
