You're a fool if you don't gap your plugs!
Old Mar 26, 2012 | 07:17 PM
  #21
hxgaser's Avatar
Multiprong plugs won't work any better, but they will has longer.
Old Mar 27, 2012 | 01:16 PM
  #22
badinstincts's Avatar
I think they would work a little worse since the extra prongs are blocking the explosions... But lasting longer, maybe... I wouldn't use them.
Old Mar 27, 2012 | 03:48 PM
  #23
shipo's Avatar
Contrary to the old four-stroke "Suck-Squeeze-Bang-Blow" adage, there should't be any "explosions" (i.e. the "Bang" stroke) inside your engine; if there are then there is something seriously wrong with your engine. What should be happening is "Inhale-Squeeze-Spark/Woosh-Blow"; not as catchy but certainly more accurate.
The difference between "Suck" and "Inhale" is purely semantics in this case, however, the burning of the air/fuel mixture should be like a rapidly advancing wave of flame and not a "Bang". To that end, the difference between spark plugs with one electrode, or two, or three, or four, or even more is virtually immeasurable. Why? A flame front is a flame front is a flame front; you get it started and step back, it takes care of itself from there through the exhaustion of the mixture.
Old Mar 27, 2012 | 03:58 PM
  #24
viperpit07's Avatar
The difference between "Suck" and "Inhale" is purely semantics in this case, however, the buring of the air/fuel mixture should be like a rapidly advancing wave of flame and not a "Bang". To that end, the difference between spark plugs with one electrode, or two, or three, or four, or even more is virtually immesurable. Why? A flame front is a flame front is a flame front; you get it started and step back, it takes care of itself from there through the exhaustion of the mixture.
EXACTLY, but i guess more prongs is supposed to ensure that all the fuel is burned and you get a more consistant spark each ignition, which imo is bogus. i got a better response in past vehicles when using say iridium over platinum vs, 2 prongs over 1.
Old Apr 17, 2012 | 10:24 PM
  #25
milan2k12's Avatar
would this spark plug be good?
NGK.com - Application Search Results
gap is .031 ..
will this be good for my 2004 audi a4 1.8t fwd 4cyl?
normal
Apr 13, 2012 10:14 AM
morpheous
Aug 20, 2010 04:22 PM
oettinger1919
Jun 15, 2009 02:28 PM
racer_x
Jan 11, 2007 01:25 AM
A4orced
Sep 17, 2005 03:15 PM
