1997 A 8 Quattro tranny issue
My 97 A8 has 141k, I just purchased it. When driving at approx. 40 -45 mph, the tranny seems to go back and forth between 4th & 5th gear. I had the fluid level checked it is ok. Also the high beam headlights, (bulbs are ok.) are not working. Any ideas?
One other thing you may want to consider, is changing the transmission fluid. When I first got mine, it shifted fairly rough, and changing the fluid helped somewhat, although it did not completely eliminate the issue. Contrary to Audi's initial assessment of a maintenance free automatic transmission on the '97 A8, the fluid should be changed out periodically.
l8r)
Well if there are no problems with the transmission and it IS the programming, he could install a TIP chip from GIAC which will change the shift patterns to a performance setting similar to newer audi's S mode.
purenorthwest
Nov 15, 2013 03:56 PM
