1997 A 8 Quattro tranny issue
Old Jul 11, 2009 | 08:06 PM
shepherd100's Avatar
Default 1997 A 8 Quattro tranny issue
My 97 A8 has 141k, I just purchased it. When driving at approx. 40 -45 mph, the tranny seems to go back and forth between 4th & 5th gear. I had the fluid level checked it is ok. Also the high beam headlights, (bulbs are ok.) are not working. Any ideas?
Old Jul 13, 2009 | 09:40 AM
auditech79's Avatar
www.ross-tech.com purchase a vag com, scan the vehicle for fault codes and then we can proceed.
Old Jul 13, 2009 | 02:41 PM
Where do I purchase one?
Old Jul 13, 2009 | 02:47 PM
Midniteoyl's Avatar
See post #2.
Old Jul 15, 2009 | 01:13 PM
ludikraut's Avatar
I used to own a '97 A8 - similar mileage on it, and it did the exact same thing. As long as the shifts aren't clunky, I wouldn't worry about it too much. That particularly annoying shift pattern is just how that years tranny was programmed. I used to just manually move the shifter down to (4) anytime I was cruising between 40-50 mph. There is a way to reset the transmission shift pattern back to default (it 'learns' your habits after a while), which helps ... for a while. At one point in time, I seriously considered doing the Tiptronic conversion, but ended up selling the car.
One other thing you may want to consider, is changing the transmission fluid. When I first got mine, it shifted fairly rough, and changing the fluid helped somewhat, although it did not completely eliminate the issue. Contrary to Audi's initial assessment of a maintenance free automatic transmission on the '97 A8, the fluid should be changed out periodically.
l8r)
Old Jul 15, 2009 | 05:25 PM
auditech79's Avatar
Well if there are no problems with the transmission and it IS the programming, he could install a TIP chip from GIAC which will change the shift patterns to a performance setting similar to newer audi's S mode.
Old Jul 18, 2009 | 05:38 AM
Thanks, I will change the fluid and see
Old Jul 27, 2009 | 09:32 PM
I changed the fluid and filter, no codes present for engine & transmission, still shiftig the same, any ideas?
Old Jul 27, 2009 | 11:15 PM
what about the chip?
purenorthwest
Nov 15, 2013 03:56 PM
vfrandy
Mar 8, 2012 05:02 PM
fabmaster911
Jun 19, 2011 02:27 PM
jmastausmc
Jan 17, 2009 04:13 PM
mchall
Sep 9, 2005 09:36 PM
