2001 A8L with P0020 Code
Old Dec 27, 2010 | 04:51 PM
ptegowski's Avatar
Red face 2001 A8L with P0020 Code
Hello Group, I have a 01 A8L 4.2L 168K mi on it with a P0020 code. I will also get misfire on a few cyl with this code. I have replaced the cam sensor on the drivers side but still throws code. It runs fine but am a bit worried because I am about to make a 1000mi trip to SC for work. Any help would be appreciated. I did a timing belt and water pump about 40K miles ago and this just started.
Old Dec 27, 2010 | 06:12 PM
silverd2's Avatar
That code indicates an electrical problem (short to B+, short to ground or open circuit) with camshaft position actuator itself..not the camhaft position sensor...at the opposite end of cylinder head, drivers side.
Anything electrical is external: wiring or signal to actuator...or the solenoid on the actuator. Solenoid should read 10-18 ohms with volt/ohm meter.
Old Dec 27, 2010 | 08:27 PM
ptegowski's Avatar
I am not sure what part you are telling me to check? I cannot find this on a part search for my 2001 A8L. Would you have any photos of this area? Thanks
Old Dec 27, 2010 | 10:39 PM
silverd2's Avatar
The yellow arrow points at cam position sensor for bank 1.
The green arrow points at the electrical connection for the solenoid that controls the cam position actuator ("camshaft adjuster"...sorry, terminology) for bank 2...adjuster tensions chain under raised part of valve cover.
The parts are on opposite (reversed) ends on banks 1 and 2.
Photo is of my AUX engine ('01 A8) with belts removed, during T-belt change.
40VCamsensoractuator.jpg?t=1293507348
Old Dec 28, 2010 | 09:31 AM
ptegowski's Avatar
Default Thanks
Thanks, I will scheck this out. Pete
Old Dec 28, 2010 | 10:33 AM
ptegowski's Avatar
Default Checked and found it
my unit measured 12.3 ohms on the drivers side. Is bank 1 on the drivers side or on the passenger side? I was told bank 1 is the drivers side. Thanks
Old Dec 28, 2010 | 10:41 AM
silverd2's Avatar
Driver's side is bank 2...#5 thru #8, front to back.
Old Dec 28, 2010 | 10:44 AM
ptegowski's Avatar
Thanks, I will check that one out.
Old Dec 28, 2010 | 10:46 AM
ptegowski's Avatar
Default P0020 Code
Does that code indicate bank 1 = Passenger Side?
Old Dec 28, 2010 | 10:47 AM
ptegowski's Avatar
Waiting for code P0020 which bank
Last edited by ptegowski; Dec 28, 2010 at 10:54 AM. Reason: Jumped the gun on my response
