Air bag light
Hey guys. I thought I saw a post about this but haven't found it again. I have my airbag light on. The previous owner said he had to replace the ignition and it has been on since. I need this light gone to pass my car thru inspection. Thanks in advance everybody.
You'll probably have to do a Vagcom to confirm exact problem, unless you are brave enough to (AND have manual) dive in there yourself....you'll blow yer head off, if you're not careful
Could be as simple as a bad connection outside the bag unit from the ignition switch job(?) ...or improperly seated bag (if he had to remove it)..not making proper contact...there's a special spring behind the bag, in the wheel that may be broken/worn, etc...could cause a loss of elec contact (not sure about that part...just heard stories...also have heard about this spring making noise when turning wheel if broken or improperly installed?).
PLUS, wear your seatbelt in the meantime.
Absolutely no way to check that without a vag com. Probably has nothing to do with the ignition switch itself, however he might have pinched the harness to the air bag in the steering wheel triggering the light.
mannyg_87
Feb 23, 2015 03:08 PM
crazybk187
Aug 5, 2013 04:29 PM
Pbcrazy
Sep 7, 2012 04:25 PM
