Audi 2001 A8 L - Intermittent vibration while accelareting
Old Mar 6, 2009 | 01:28 AM
Batya's Avatar
Default Audi 2001 A8 L - Intermittent vibration while accelareting
Audi 2001 A8 L, car intermittently vibrates only when accelerated. All four wheels were balanced twice recently. Also recently replaced both front (left and right) axles, front brake rotors and pads.
Old Mar 6, 2009 | 09:45 PM
auditech79's Avatar
Do you have aftermarket wheels? If so, did you have the hubcentric rings installed with them?
Old Mar 9, 2009 | 02:33 PM
Batya's Avatar
Thanks for your response. I just got this car about 6 month ago from auction. Frankly, I'm not sure whether it has hubcentric rings or not. I'll check with my mechanic. All four rims are original, not bended. Though, one tire (out of 4) is from different manufacture (!). Vibration appears only under acceleration (at ~50-60 mi/h and above) and especially when driving uphill or downhill. It looks like vibration feels more on the passenger side (both front and back) and it seems to come from under the carriage.
Once again I really appreciate your help!
Old Mar 9, 2009 | 10:47 PM
auditech79's Avatar
You won't need hubscentric rings if they are the original wheels, although the fact that one of the four wheels aren't original makes me wonder.....
I would have all four wheels put on a balancer, if they are all good, then have the tech put the wheels back on the car and have him drive it up to speed (ESP off) while on the rack and see which wheel is causing the problem.
Old Mar 10, 2009 | 02:28 PM
CrazyEights's Avatar
you could be missing wheel balancers or weights on one of the wheels... just an idea... my stock forged fat fives have weights throughout the inner wheel lip.
Old Mar 11, 2009 | 11:02 AM
Batya's Avatar
Guys, thank you very much for all your help. My next step is to replace all four tires. I’ll let you know if it resolved the issue.
Old Mar 14, 2009 | 01:50 PM
gpoc's Avatar
Im thinking intermittent while accelerating points more to cv joints not tires/wheels. Check all the rubber under the car for leaks etc.
Old Mar 19, 2009 | 10:15 AM
Batya's Avatar
Installed four new Michelin Primacy MXV4 tires. Car runs much smoother, but vibration still occasionally occurs It is less, but it exists. I recall my mechanic mentioning that one of my front upper control arms had damaged rubber. Could this cause such vibration?
Guys, I really appreciate all suggestions.
Old Mar 19, 2009 | 02:50 PM
auditech79's Avatar
No it can only be caused by a rotating mass. Have the mechanic take off your wheels and measure the out of rounds on your brake rotors. Do you feel any vibration when applying the brakes also?
Old Mar 20, 2009 | 01:04 AM
Batya's Avatar
No, I don't feel any vibration when applying the brakes. It only happens when I accelerate.
