Brake fluid question
Old Feb 6, 2008 | 04:39 PM
Phoenix2k's Avatar
Default Brake fluid question
I have a 2005 A8l Audi that has a red "brake" light that intermittently flashes and beeps, which I believe means that I am low on brake fluid. Question: does the Audi 45ooo mile service include topping off all fluids?
Also, I bought Castrol brake fluid which reads that it "exceeds all Dot 3 and4 specifications". Can I add this fluid without harming my car (in other words, does the brake fluid thats already inside my car have to be the same as the one I add?). Auditech, please feel free to chime in with your obviously superior knowledge base.
Mario
Old Feb 6, 2008 | 05:45 PM
Phoenix2k's Avatar
Default RE: Brake fluid question
I know you guys know the answer!!!Help!!!
Old Feb 7, 2008 | 12:29 AM
dankhound's Avatar
All of the services include topping off fluids. Its very posible the brake light is on due to low brake fluid. The type of fluid should be printed on the cap for the brake fluid reservoir. Itll be dot 3 so the stuff you have will work fine. There is a screen in the reservoir that will make fluid gather in the top. You may need to use a screwdriver to pry in between the screen and the reservoir to get fluid to flow past the screen.
Old Feb 7, 2008 | 09:45 AM
jaeder's Avatar
Check the brake pads, when worn past a certain thickness a sensor is tripped.
sollyd25
Jul 28, 2011 10:08 AM
B5 Audi
Nov 27, 2009 05:24 PM
AR15Texan
Jun 10, 2009 12:24 PM
JDUB
Jun 22, 2004 01:43 AM
