Coolant depletion
Old Jun 10, 2006 | 12:27 PM
Zealan's Avatar
Default Coolant depletion
All,
Looking for help. Have a 1997 Audi A8, and my coolant reservior will lose about 1" of water in 2-3 hours or so of running. I cannot find any leaks under the car anywhere, believe I have looked. The oil is not milky so it is not going there. The exhaust seems normal and is not white. Anybody have a similiar experience? My fear is somehow I am burning it through a bad head gasket.
Thanks,
RJ
Old Jun 10, 2006 | 04:04 PM
dan908's Avatar
Default RE: Coolant depletion
That is a pretty old car, does your coolant reservoir hold pressure (pressure test it)? The coolant reservoir gets brittle and cracks and then if it is not holding pressure it will steam off your coolant. Try the res. cap too (pressure test). If you can't find/ don't have a pressure tester (it is like a bike pump with a radiator cap) drive around and get it warmed up then open the hood and check for steam coming off. If it is a cap though you probably won't notice it.
No oil in the coolant or coolant in the oil I would say you are leaking or steaming off.
Old Jun 11, 2006 | 01:31 PM
dankhound's Avatar
Dont forget about the heater core. That will produce a leak under the dash.
Old Jun 11, 2006 | 02:06 PM
techbod's Avatar
most common coolant leak on the V6 is below the plenum so out of sight and very hard to see, best to remove the plenum to investigate
Cioffie
May 19, 2013 10:24 PM
GLD
Dec 6, 2008 05:22 PM
Ph3N0m
Oct 21, 2008 12:58 PM
less_of_me
May 2, 2007 03:29 AM
