determing correct rotors / pads
Old Nov 10, 2013 | 02:15 PM
1999jayman's Avatar
Default determing correct rotors / pads
I need to replace front brakes on 2000 A8L, date of mfg is July, 2000. Asking Audi dealer to research from my VIN results in "doesn't have time", "make an appointment for service, blah blah" There are no numbers whatsoever on the rotor hub. (assume PO replaced them). Research tells me there are apparently 3 different rotor / pad set up. Looking at Blauparts, there are three choices:
option 1- 312mm with 4 pad system
option 2 - 323mm with 8 pad system
option 3 - 345mm with 4 pad system
I understand the 8 pad system is Akibono (spelling?) Since only one option offered by Blauparts is for the 8 pad and mine has the 8 pad system does that mean option 2 is correct? Is it possible to have either other rotor with the 8 pad?
Yes, I understand I could measure them but it's cold outside today, (I'm a wuss) and I'd like to order them tomorrow.
Pictures are attached but I don't know if that helps. Maybe pics will reveal something to others.
Attached Thumbnails determing correct rotors / pads-brakes-nov-2013-001.jpg   determing correct rotors / pads-brakes-nov-2013-002.jpg   determing correct rotors / pads-brakes-nov-2013-004.jpg
Old Nov 10, 2013 | 04:06 PM
M5S5's Avatar
Tech Certified
Looks like you have option # 2. I can not tell for sure with the picks but it looks like you have 2 pads on each side of the brake rotor which would be the 8 pad set.
Old Nov 11, 2013 | 05:30 PM
ex56TT's Avatar
Banned
go with ATE slotted, they do a good job plus they look badass!
Old Nov 15, 2013 | 01:33 PM
snapdragon's Avatar
Check the PR codes on the wheel well sticker, these have the codes for front and rear brakes which you can match with those in the catalogues of various makes.
AudiEnthusiasts Master
Old Nov 19, 2013 | 04:51 PM
ex56TT's Avatar
Banned
just dont go cheap, if you get them at rockauto.com, they will warp quick. i get them at audi dealer, i know, i rarely say that ... but its true. they sell very good brake rotors, and there is a ton of cheap parts out there.
DaRealDVS1
Sep 23, 2014 11:33 PM
techy101
Jul 30, 2013 12:27 PM
Sizz
Aug 18, 2011 10:49 PM
milo55041
Oct 26, 2007 05:32 PM
milo55041
Oct 8, 2007 09:19 PM
