Disabling DBS?
Old Oct 15, 2007 | 12:07 PM
sirics's Avatar
Default Disabling DBS?
Hello,
Does anybody have a step by step guide on how to disable the DBS function using the vag com software. My 97 A8 Quattro is doing that annoying shifting like shifting into 4th gear and not even reaching 40mph. Any help is appreciated.
Thanks
Old Oct 15, 2007 | 04:20 PM
auditech79's Avatar
Default RE: Disabling DBS?
Are you asking if you can change the shift points? The VAG COM can't change the software in the TCM, you can however take out the TCM and send it out to a company like GIAC and get a TIP CHIP, which turns the tranny into a shifting beast. You can red line the shifts if you want, it shifts a lot harder and more crisp ect. It costs around $600 to get a tip chip.
Old Oct 16, 2007 | 10:38 PM
sirics's Avatar
No my bad, I was asking if it is possible to disable the DSP feature (dynamic shift program) using the Vag com software? I think I did it but there is no change in the shifting patterns. The transmission still shifts too early. It goes in the fourth gear and I am at 40mph only. I have used the numbers 00012 and 00011. I tried inputting 00010 but it would not take it. Any suggestions?
Thank you!
Old Oct 17, 2007 | 04:22 PM
auditech79's Avatar
No you can't do anything with a VAG COM to the trans, you can change engine things using the VAG and Lemmiwinks software but not the tranny.
The best thing for you is to invest in a tip chip, you won't be dissapointed.
Old Oct 17, 2007 | 11:24 PM
sirics's Avatar
Thanks for the reply. Do you have any suggestions on where to get the tip chip? And will the stupid shifting problems go away do you know? Thanks!
Old Oct 19, 2007 | 02:31 AM
auditech79's Avatar
It will completely re-map the shifting patterns, so its gonna be like driving a new car all together.
As for the tip chip, you need to find a GIAC dealer near you, you can either send out your TCM yourself (which is under the carpet on the passenger's side) or take it to the installer itself and have them do it all for you.
mikeg1618
Jan 17, 2012 02:43 PM
k2nix
May 16, 2011 12:00 PM
a2thy
Jul 2, 2010 05:14 PM
a2thy
Jun 5, 2010 02:47 PM
a2thy
Jun 5, 2010 02:33 PM
