HELP! Noticing transmission slip at 3-4 shift
Old Jan 25, 2008 | 06:25 PM
BTV8's Avatar
Default HELP! Noticing transmission slip at 3-4 shift
Oh no... over the past few weeks, I've been noticing a slight slip between the 3-4 shift under light/moderate acceleration on my 2005 A8.
It's barelynoticeble and just a little (ie. engine flare-up only the width of the tach needle) but there nonetheless.
Car has 50,100 miles andit started happening right after the warranty expired! - Arrrrgh!
Recommendations? Fluid change? (I believe it's original fluid), Vag-Com adjustment? Thing is, nothing has ever gone wrong with this car till now... I was sure I had a "good one".
Help!
Old Jan 25, 2008 | 06:40 PM
dankhound's Avatar
Default RE: HELP! Noticing transmission slip at 3-4 shift
Theres a tech bullitin to swap the fluid to a newer style for a chirping noise on the 3-4 shift. Not sure if the chirp could be related to the slippage. Only problem is the fluid is like 100 bucks a quart and the bullitin requires 12. You have to flush out the old fluid.
CollegeKid94
Mar 11, 2014 09:26 PM
vtraudt
Sep 25, 2010 10:39 PM
Lesgoaudi
Jul 7, 2009 11:07 AM
dsnoland1
Feb 10, 2009 06:38 PM
SonOfDenny
Sep 13, 2008 06:16 PM
