hissing noise at engine turn off.
Old Nov 6, 2008 | 08:05 PM
gmudan's Avatar
Smile hissing noise at engine turn off.
hi,
on the 2004 A8L is it common to hear a "hiss" when the engine is turned off ,
looks like the suspension goes down, i don't hear this if the engine is running , the suspension seems ok and is level all around, it seems to go up and down at speeds and maintains its height.
one more question ...how long (safely) can you go with out changing the timing belt,
if anybody has had one done from the dealer???how much???
thanks.
Old Nov 6, 2008 | 08:18 PM
auditech79's Avatar
Try spraying the airbags with soapy water to see if you can find a leak in the air bags.
As for the timing belt, you don't want to wait more than 80-90k to change the belt.
You can buy a kit for cheaper at www.ecstuning.com or www.purems.com then have a good euro shop replace it.
The dealer would charge you around $2,000 to do it.
auditech79's Avatar
Oh and you want to do the water pump and thermostat along with the belt too.
Old Nov 7, 2008 | 06:41 PM
gmudan's Avatar
Default where is the airbag you are referring to?? is it under the fender?
air bag location??
Old Nov 7, 2008 | 08:32 PM
auditech79's Avatar
Air bags are whats holding up your car, they take the place of a standard coil spring. Its behind the wheels on all four corners. Take off one of the wheels and you will see em. Just make sure to put the car in jack mode before lifting the car off the ground.
You do that through the MMI, select car, scroll down to air suspension, and put it in jack/service mode.
Old Nov 8, 2008 | 11:16 AM
gmudan's Avatar
thanks auditec79..you are a great help....if they are leaking would you know if this is covered under the extended warranty ?? it is the certified pre owned .
Old Nov 8, 2008 | 12:58 PM
auditech79's Avatar
They should be covered. Just tell them that the car starts to lower itself over night.
Old Nov 8, 2008 | 04:59 PM
gmudan's Avatar
many thanks again...
Old Nov 10, 2008 | 01:07 AM
kegwa's Avatar
Member
Thanks for sharing the links. It helps me.
Cameron farooq
Jun 8, 2014 06:29 AM
audiblacky
Dec 14, 2012 10:55 AM
Yasin Duman
Dec 13, 2011 12:28 PM
03allroad
Jan 2, 2009 09:10 PM
audidude89
Dec 26, 2008 10:28 AM
