P0174 error
Old Nov 12, 2010 | 07:48 PM
ludikraut's Avatar
Default P0174 error
Getting a P0174 error on my '04 A8. I'm assuming this code on the A8 is the "Fuel System Too Lean (Bank 2)" code. Which cylinder bank is denoted as bank 2 on the A8? Any common issues that would cause this - i.e., specific vacuum leaks, etc.?
l8r)
Old Nov 12, 2010 | 10:36 PM
silverd2's Avatar
l8r)
That's the driver side, #5 - #8. Haven't heard of a common cause/problem...but vacuum hoses would be my first guess...just a guess, though...haven't ever had that code.
Old Nov 14, 2010 | 12:16 PM
auditech79's Avatar
P0174
Fuel Trim,Bank2 System too Lean
Like silverd2 said, being lean on one bank generally boils down to a vacuum line. Its probably about time to go thru them all and replace as many as you can see thats damaged or frail looking.
Old Nov 14, 2010 | 02:43 PM
ludikraut's Avatar
Good news, I took a look, and the clamp holding the MAF to the intake snorkel had wormed its way loose. Tightened it up, and the CEL cleared after about an hour's worth of light driving. All the vacuum hoses still look in good shape.
l8r)
Old Nov 14, 2010 | 08:15 PM
auditech79's Avatar
Must have happened after the last oil change service, the MAF has to be taken out to remove the air box.
Old Nov 14, 2010 | 08:24 PM
ludikraut's Avatar
^ Probably, in which case I was the culprit. Although, ironically I fixed the MAF to begin with, since whoever did the oil change before me, didn't have it aligned properly (although they did have it clamped down.
l8r)
The Bebop
Apr 15, 2011 01:28 AM
DaSbOoT_509
Apr 8, 2011 02:29 AM
cwedholm1
Mar 24, 2010 09:05 PM
ilovelagar
Oct 22, 2008 12:37 PM
Rodneylynn1977
Jul 17, 2008 11:00 PM
