Rear door window
Old Feb 24, 2008 | 06:13 AM
Albee G's Avatar
Default Rear door window
Hello everyone,
Could someone please tell me whether a bentley manual will explain how to remove and install the rear door power window in a 2002 A8L? If so, is this work within the realm of average humans?
Thanks,
AG
Old Feb 24, 2008 | 08:47 AM
techbod's Avatar
Default RE: Rear door window
Rear door[/align]Removing and installing rear window lifter[/align]
â—Rear door trim removed: [/ul]
Rear window lifter
â—†To remove, drill heads off rivets -item 45- and knock out shanks.
â—†Start by riveting on window lifter at location marked by arrow [/ul]
Blind rivet
â—†6 off
â—†Always use genuine rivets to avoid contact corrosion: [/ul][/ul]
=> Parts List
Door subframe
â—†Removing and installing[/ul]
Motor for window lifter
â—†Detaching connector
=> Fig.16
17
â—†After installing, raise window as far as it will go
â—†Then press window lifter switch again for at least 1 second in "close" position to activate automatic down/up function [/ul]
Release and tighten bolt - 10 Nm
â—†3 off [/ul][/ul]
Clip
â—†Fit window lifter -item 26[/size]27- in clip and fasten clip -arrow- [/ul]
Guide pin
Damping washer
Washer
Locking plate [/ul]
→ Fig.1Unplugging connector
‒Unclip the two-pin connector to rear (arrow) to remove from three-pin connector. [/ul]
[IMG]local://upfiles/12092/6C22580872884EC8BA7EAB27FFD82EB8.jpg[/IMG]
[IMG]local://upfiles/12092/A803E9F7ACA04E45BFF57DAEED697734.jpg[/IMG]
Old Feb 24, 2008 | 08:55 AM
techbod's Avatar
Rear door trims[/align]Removing and installing rear door trim[/align]
Removing
‒→ Carefully lever cover strip -3- out of fasteners at door trim.
‒Press pin -1- on expanding clips -2- in by about 4 mm and detach expanding clips. [/ul]
Notes:
â—†Do not press pins completely out to remove door trim
â—†Depending on date of manufacture cross-head screws may be fitted instead of expanding clips [/ul]
‒→ Use blunt screwdriver to lever off bottom part of recessed handle moulding -arrow-.
‒Take bottom part of recessed handle moulding out of door trim. [/ul]
‒→ Screw out bolts -3- for top part of recessed handle moulding -2-.
‒Lift top part of recessed handle moulding out of door trim -1-. [/ul]
Note:
With one-piece top part of recessed handle moulding front section of top part (with switches) has to be additionally unclipped from door trim and connector detached.
‒→ Screw out hexagon bolt -arrow-. [/ul]
‒→ Remove cross-head screws -2- and -3-.
‒Detach bonding of rear filler piece -1- at window frame. [/ul]
‒→ On vehicles with electrically adjustable individual seats screw out cross-head screw -1- of switch mount -2- at door trim.
‒Take out switch mount and detach connectors -3-. [/ul]
‒→ Unclip door trim -2- from carrier for door components. [/ul]
1 -Retaining clips for door trim [/ul]
‒Lift out door trim over locking ****. [/ul]
‒→ Tilt door trim and lever clip -1- off Bowden cable -2- of door opener.
‒Detach nipple of Bowden cable with retaining clip -3- at door opener. [/ul]
Note:
Take care not to lose Bowden cable retaining clip.
‒Detach all connectors of wiring harness in door trim.
‒Take wiring harness out of door trim. [/ul]
Installing
Installation is carried out in the reverse order; note the following:
‒→ Ensure that all retaining clips -2- engage properly in carrier for door components. [/ul]
[IMG]local://upfiles/12092/CA6313581F9D4F25B4611871AAB2F00E.jpg[/IMG]
[IMG]local://upfiles/12092/323F1B1C8F0A4282B45BFC6E644AB357.jpg[/IMG]
[IMG]local://upfiles/12092/B9A05A80A09E4469800BB066AC3D8A73.jpg[/IMG]
[IMG]local://upfiles/12092/64EB8FB3A19D44539AC97A3AB811D7B0.jpg[/IMG]
[IMG]local://upfiles/12092/E46CFF663B664AA8AB454F4BE9688109.jpg[/IMG]
Old Feb 24, 2008 | 08:56 AM
techbod's Avatar
last few pictures
[IMG]local://upfiles/12092/B27CEF50B8FA448ABC5BA8A3188F4F20.jpg[/IMG]
[IMG]local://upfiles/12092/025077457E1A42E7B8F530AB13D2F114.jpg[/IMG]
[IMG]local://upfiles/12092/0988DF4C3B0F441C9F7ECBEEB614B148.jpg[/IMG]
Old Feb 25, 2008 | 07:31 PM
Albee G's Avatar
Techbod,
Thanks so much for the info. Seems withinrange of my mechanical abilitiy. Did this stuff come from Bentley?
Love the cat icon!!!!
AG
lord_of_lostock
Mar 28, 2013 02:59 PM
kenyon
Jan 21, 2011 12:46 AM
kenyon
Aug 4, 2010 07:42 PM
thesupremeg33k
Oct 7, 2007 08:47 PM
neville67
Jul 17, 2007 09:25 AM
