tire pressure malfuction.
Old Nov 24, 2007 | 09:20 AM
gmudan's Avatar
Default tire pressure malfuction.
tire pressure not displaying .... after kept in garage for a month ....warning light comes on when display option selected .
ran vehicle on highway , but still not displaying
Old Nov 24, 2007 | 12:49 PM
auditech79's Avatar
Default RE: tire pressure malfuction.
Depending on what year A8 you have you must re-initialize the system then go on about a 20 minute drive cycle for the wheel sensors to show a pressure.
If you have an older D2 car then you probably need new sensors, the batteries inside the sensors are only designed to last about 4-5 years.
Old Nov 24, 2007 | 01:29 PM
gmudan's Avatar
thanks ...my A8 is 2004...the dispaly was working before i parked it (for a month) .
how do i "re initalize the system"?
thxs
Old Nov 24, 2007 | 02:10 PM
auditech79's Avatar
Use the MMI, go throught the CAR set up and you will see tire pressure monitoring, select initilize wheels and go on a solid 20+ minute test drive.
Old Nov 24, 2007 | 02:17 PM
gmudan's Avatar
it does not have the option initilize wheels, it is a 04 a8, it only has display tirepressure, store current tire pressure, and system on>off
Old Nov 24, 2007 | 02:24 PM
auditech79's Avatar
So then store the pressures and take it for the test drive, the older MMI systems will do the same thing by storing the pressures. If it doesn't work then there is an issue with the system and needs to be diagnosed.
Old Nov 24, 2007 | 02:37 PM
gmudan's Avatar
There are no pressures displayed so you cannot store them.
Old Nov 24, 2007 | 02:41 PM
dankhound's Avatar
You have to store the pressures first. Then the system will learn the pressures in the tires and display them.
Old Nov 24, 2007 | 02:46 PM
gmudan's Avatar
ok gone for a test drive and will let u know after arrived.
Thanks Very Much
Old Nov 24, 2007 | 04:10 PM
gmudan's Avatar
Went for a test drive for 1hr at 100, dosent work
