transmission codes
Old Oct 6, 2007 | 08:35 PM
xx216xx's Avatar
Default transmission codes
Anybody have any suggestions as to the first place to look to fix my car? It keeps going into limp mode once I put it in D and press on the accelerator, it doesn't do it when i first start the car. Should I go ahead and try replacing the TRS or is there something else I should look for? The codes are:
Address 02: Auto Trans
Control Module Part Number: 4D0 927 156 K
Component and/or Version: AG5 01L 4.2l4V USA D29
Software Coding: 00002
Work Shop Code: WSC 02314
5 Faults Found:
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 35-10 - - - Intermittent
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
P0730 - 35-00 - -
P0730 - 35-00 - -
P0730 - 35-00 - -
18169 - Shift Lock Solenoid (N110): Short to Ground
P1761 - 35-10 - - - Intermittent
Old Oct 6, 2007 | 11:52 PM
AWDaholic's Avatar
Senior Administrator
Default RE: transmission codes
send this as a PM to rayveedub and auditech79 One or both should be able to answer your question
Old Oct 7, 2007 | 02:24 PM
auditech79's Avatar
Sent PM
Old Oct 7, 2007 | 02:46 PM
techbod's Avatar
ORIGINAL: Wadaholic
im disappointed you didn't mention me I have all the codes, I think its time for me to retire
Old Oct 7, 2007 | 04:33 PM
auditech79's Avatar
ORIGINAL: avant80@2.6
ORIGINAL: Wadaholic
Nah 80 you're a pimp, your name just doesn't show up in the tech certified area. I don't know why, maybe because your in the UK?
Old Oct 8, 2007 | 07:09 PM
AWDaholic's Avatar
I talked to redgoat about that, too. As far as we can tell, the "@" in the middle of his S/N is preventing him from showing up.
Sorry I left you out. No slight intended, mate. Top billing from here on...
Old Oct 9, 2007 | 01:49 PM
xx216xx's Avatar
So, quick question, I'm being told that the Transmission Range Sensor is also called the Multi function switch...is that true?
Old Oct 9, 2007 | 08:37 PM
auditech79's Avatar
ORIGINAL: xx216xx
Of course it could be called that, it serves as a saftey switch for your starter, saftey switch for your cruise control, can switch between tip tronic and regular automatic mode ect.
Old Oct 11, 2007 | 03:38 PM
xx216xx's Avatar
Thanks for all the help, I've ordered it and will replace it this wknd, hopefully it fixes everything.
roomforelvis
Jan 2, 2012 11:24 PM
tinfoyle
Oct 2, 2009 08:07 AM
slmiver
Aug 28, 2009 10:37 AM
SuperFlea
Apr 4, 2009 06:12 PM
jungleb0y
Sep 6, 2006 07:52 PM
