TV Tuner
Old May 31, 2012 | 10:14 AM
schiu's Avatar
Default TV Tuner
My tv icon is missing from the MMI. The dealer said i need a new tuner. I did check the fuse on the fuse panel and it is ok. Is there another fuse inside the actual tuner
Thanks
Old Jun 3, 2012 | 01:17 AM
Brozee's Avatar
Isn't it all digital now; don't even think it would work regardless.
Old Jun 3, 2012 | 09:39 AM
jakematic's Avatar
I don't think there is a fuse inside the tuner module.
Check all the connections (fibre, FBAS, FAKRA, etc) and if you have VCDS (VAG-COM) or know someone who does a scan will help.
Not sure which country you are in, but I've seen a few of them on ebay.de and of course kufatec.de has them.
There's a company in the UK who parts out A8's on ebay that might be worth a look.
In the US you might try audiusaparts.com or worldimpex.com - anywhere else is going to be less than the dealer.
Old Jun 3, 2012 | 08:00 PM
schiu's Avatar
Thanks for your reply . I did check the connections and they are fine the vcd cannot detect the tv tuner . The tuner seems to be quite difficult to remove as it's on the inside of the rack and a lot of wires around it . Do i need to remove everything in order to unbolt the tuner
Old Jun 3, 2012 | 10:07 PM
jakematic's Avatar
Will try to look at the Bentley tomorrow if time allows.
Seem to recall the tuner is attached to the radio receiver on the back but not 100% sure.
In most cases you can unbolt the rack itself and tip it forward to get the components in/out.
In the interim this post may help.
Old Jun 22, 2012 | 07:26 AM
schiu's Avatar
I've checked the connections on the tuner and they are fine .I've forgotten to mention that not just the TVicon is missing on the MMI but also the AV1 &AV2. Could it be an interface that is playing up and where is it located if there is one
Thanks
nickthemayor
May 1, 2008 04:32 PM
flynbvr
Feb 6, 2008 07:24 PM
solo92s10
Dec 10, 2007 05:18 PM
wee06
Nov 28, 2005 09:49 PM
ShakariX
Nov 9, 2005 06:16 PM
