Audi Q5 The Audi Q5, aerodynamics have never looked so good.
Help - Sticking Q5 console switches
Old May 3, 2011 | 01:24 PM
Michaellmcc's Avatar
Question Help - Sticking Q5 console switches
Passenger spilled coke on the console, and as a result some of the navigation and other switches are sticking and not always returning/releasing. Any suggestions on a fix?
Is there a safe, thin cleaner that would not harm the switches or plastic parts?
Can each switch be removed individually for cleaning or replacement?
All ideas would be appreciated.
Old Sep 22, 2011 | 09:48 AM
kchao2000's Avatar
Check with car detail shop see if they have anything to clean it. Some of switch probably can be remove individually and replace but not all of them. For those can't be remove individually, you may need to get entire switch unit to replace it.
I don't allow anyone (including myself) eat or drink in my car just for this reason.
Old Sep 22, 2011 | 01:23 PM
brrman's Avatar
You can get a small aerosol can of "electronics cleaner" at radio shack - the kind with the small red straw. I have done that to my car's buttons and it has fixed the problem. It flashes off really fast so does not need much cleanup.
Old Mar 19, 2016 | 01:53 PM
cmacedo's Avatar
I had the same issue with a Honda Accord, the answer is mineral water (no chemicals) and vacuum cleaner, at same time drop water inside with siringe and vacuum. Turn ignition off. Don't expect to do in a minute!!!
jonbonesjones
Apr 1, 2013 10:08 AM
Audi_convert
Sep 27, 2008 04:04 PM
Dallas09
Jul 23, 2008 10:58 PM
SurferForever
Nov 9, 2006 11:14 PM
GraffixWB
May 20, 2006 02:37 PM
