Audi Q5 The Audi Q5, aerodynamics have never looked so good.
Q5 cabin filter replacement how-to
Old May 26, 2011 | 07:15 PM
mattsedona's Avatar
Default Q5 cabin filter replacement how-to
I recently replaced the cabin filter in the wife's 2010 Q5 and the directions I found on this site were not entirely correct, at least for her car, so I thought I would update the procedure, which is stupid easy. This is part of the 15k service, which also includes an oil & filter change.
1. remove the passenger front floor mat
2. unscrew the two black screws holding the cover in place, just at the top of the carpeting. You do not need a screwdriver for this just turn the black *****.
3. remove the white plastic lid securing the filter by sliding it horizontally, away from the center console. Once it has moved an inch or so it will come off.
4. pull the old filter out and down, will need to bend it a bit to get it out.
5. install is reverse of above.
All this should take 10 minutes the first time and 3 minutes the next time. It helps to have a nice bright light handy. A new replacement filter was $22. I think the dealer charges over $60 for this service, which is really a rip. If anyone has trouble doing this and needs me to post some pixtures, just let me know and I will oblige.
Old Dec 4, 2011 | 06:25 PM
daberlin's Avatar
Default Q5 Cabin Filter Replacement
Please note - there are THREE (not two) hand twist off screws that hold the foam cover that allows access to the cabin filter holder. The third screw is closest to the firewall and towards the center console.
Old Dec 13, 2011 | 09:51 AM
kchao2000's Avatar
RickA6
Sep 28, 2016 11:19 PM
murfaudi
May 21, 2015 01:18 PM
sjbartley
Jan 11, 2012 08:52 AM
md67stang
Jul 18, 2009 04:53 PM
allroad-AUS
May 1, 2009 01:42 PM
