Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
2007 Audi Q7 Amp Fried by Water
Old Jan 26, 2017 | 02:51 PM
  #21
Jocelynn956's Avatar
Originally Posted by AudiTech028
You can install a used amp but will still need to take it to the dealer to remove the component protection on the amp online and possibly code it correctly. However this doesn't cost nearly 1/4 of what they would charge.
I still have 3 amps in working good condition if any one is interested. $450 shipped obo.
Was just wondering if you still had any amps available? My amp went out due to water damage and am interested in an amp.
Old Mar 18, 2017 | 10:08 PM
  #22
Mike Copeland's Avatar
I have several factory amplifiers for sale if you interested.
Can you call me. My number is 708 731 1967 I have a 2007 Q7,and need a amplifier. They say my drain tubes was leaking.6
Old Mar 18, 2017 | 10:11 PM
  #23
I need a amplifier for a 2007 Audi Q7. Model number 44L0919223D asap. And sum leads because my drain tubes are leaking and my front and second row sun roof dosent work.
Old Mar 18, 2017 | 10:15 PM
  #24
I need a amplifier for a 2007 Audi Q7. Call me sumbody model number 44L0919223D
Old Mar 8, 2019 | 05:43 PM
  #25
tebreshiap@ymail.com's Avatar
Default Amp issues
Hello any dealers here with the amp for sale. I’m having the same issue with my 2009 Audi Q7... water damage has fried my amp as well. Thanks!
Old Mar 21, 2020 | 09:28 PM
  #26
agustincorrea2020's Avatar
Originally Posted by Zen217
Hi. I have the same issues with my 2007 Q7 as well. I havent had issues with my Service Department here in the US, however they estimated my repairs to be over $3000 (repair leak and new amp). I am also having problems with my battery running low and I assumed that it was becuase of the fried amp, and I guess my assumtions were correct! I havent had much luck with finding a used amplifier (that I can trust) here in US. Its not often that they post one on Ebay but it's gonna cost around $600 for one (used). If/when you get your DIY, please let me know. I would like to repair the amp myself. Thanks for your post. It was certainly helpful!
I repaired mine with a new circuit board and its working fine. Have a 2009 Q7 and was missing the right side music will have to find a tuner receiver that may help fix my issue with the right side no sound and trunk subwoofer too.
Old Feb 20, 2021 | 09:24 PM
  #27
AugieCorrea's Avatar
Hi all my 2009 Q7 amplifier was replaced with a board from China purchased thru eBay and took the car to an Audi dealer and the made it work. Fix the water leak with a new hose from the sunroof right side area and no more water leaks anymore coming directly to the amplifier and rear right seat belt. Here in Florida it rains hard in summer time and was the main reason that damaged the amplifier and battery draining every day.
The new circuit board was $198.00 on eBay a new 5/16 clear hose and a metal clamp for $8.00 amd $155.00 dealer service and enjoying the stereo system every time I use my Q7.
Old Oct 9, 2021 | 05:22 PM
  #28
nh32rg's Avatar
Default fix it yourself not hard.
I went to a u-pull yard and got an amp from a 2006 A6 for $30CDN. There are two chips on the board you have to swap for the security feature but it's super easy, anyone can do it (if I can!). I got a rework station off Amazon for $80CDN and had zero prior experience. Swapping the chips took less than a minute. Just blow the hot air over the chip and pull up with some tweezers until it releases. On the donor board just place it and hold the chip down and apply hot air until it "sits". Didn't need any extra solder or flux or anything. Instructions I found online here https://www.opuradio.com/blog/how-to...l-a8-mmi-2g-15. One thing is he has A1 B1 on the first pic but should be labelled A1 and A2. So after I did that and it all worked I went out about a week later and the spare tire well was full of water because I didn't properly fix the leak! Had to get another amp and start over. Here's how to fix the leak, which is also easy and when I say that I mean I just followed the video and had no issues. https://m.youtube.com/watch?v=SPrD9Jfqy_s. Most of the headliner is held by clips so easy to pull down.
Kathy-Jo Bizeau
Feb 20, 2021 09:41 PM
hughm
Feb 21, 2018 04:12 PM
Raymon Silva
Mar 10, 2017 05:39 AM
kmjunk
Audi Q7
18
Jun 23, 2015 02:20 PM
cmg
Audi Q7
Apr 12, 2013 04:19 PM
