Audi Q7 The Audi Q7, beauty on and off the streets. Refined styling paired with power and advanced technology.
Replace Q7 front rotors and pads
Old 05-11-2012, 10:45 PM
dgjks6's Avatar
Default Replace Q7 front rotors and pads
This is my first post on the Audi forums, so first you get a little background about me and my wifes car.
And this is going to be a long post, take several days, and probably not go right, but hey, that is the story of my life.
Gas prices were on the rise, my wife had a Ford Excursion with 175,000 miles and she wanted something with better gas mileage. We looked at the new 4 cylinder Chevy Equinox and the dealer next door was an Audi dealer. So she went there and looked and fell in love with the economical Q7 3.6. So last fall we purchased a 2008 Q7 with 27,000 miles for $35,000. Now it has 40,000 miles and she took it to the dealer to fix a "dipped beam" - that is what she said. The dealer came and got the car and said, "hey, you need new front rotors and pads! (for $750)".
I tend to be cheap and I am willing to try new things, so I figured out long ago how to change brakes and rotors - usually just go to autozone and get new stuff and go home and slap it on. I have done the Excursion several times, a Pontiac Grand Prix several times (daughters car with 102K), and did the pads on a VW. I also read that the Audi goes through pads brakes every 20-25K miles, so I was not going with OEM.
Never worked on an Audi before.
So here is step 1 - get a manual. I ordered it online and will let you know how it is when it arrives
Step 2 - get parts
Looked on ebay and did research.
I went with Monroe pads:
For rotors I chose Raybestos. And this is how things go for me because I try to save a buck. So the Raybestos rotors were $120 from most places, but I found one for $61. I ordered them and this is what I got:
Turns out they are not real raybestos rotors. But for $60 each I am going to give them a try.
Now for the reason I am writing this post. To help all of the q7 owners out there who want ot do there own brakes. Yeah right. It is because I tend to keep things a long time and if I record this, then in the future I can come back to it so I know how to do it. And if I can help someone, all the better.
So in this post you are going to get costs, time, pictures, and commentary. And a review of the rotors and pads.
So day 1 - online research and buy parts
CD manual - $25.95
pads - $47.90
rotors - $122.10
Total Cost = $195.95 (shipping included)
Total Time = 1 hour - research and ordering
Part numbers - MONROE DX1014A
Raybestos 980310 and 980311 (different for left and right)
Day #2 (today)
rotors and pads arrived
Total Cost $195.95 - no change
Time - 20 minutes staring at my new parts
Total Time 1 hour 20 minutes
When the manual arrives I will give the next update.
Old 05-12-2012, 05:06 PM
Audi Tek's Avatar
Tech Certified
Your going to regret being cheap with brakes. Same thing with tires. I understand the dealer is alot of money. You should always find something in the middle.
Just so you know the front are directional. There is a left and a right.
Old 05-12-2012, 09:06 PM
dgjks6's Avatar
Day #3. Ran to the mailbox expectantly so I could get the CD repair manual. But, alas it was not to be. Maybe monday.
As far as cheap rotors, I know. That is why I went with Raybestos brand. That is not what I got, but I figured I can try the cheap ones since I had them. And anyway, it is my wife's car.
I did notice they were directional. Still trying to figure out how a rotor can be directional.
Old 06-02-2012, 07:32 PM
dgjks6's Avatar
Day 20 something. Finally did it today. So first we are going to go with all of the costs.
Rotors = 122
pads = 48
new retainers = 12
new bracket bolts x 2 = 24
wrong size bit to remove rotor = 15
right size bit to remove rotor = 10
brake cleaner = 5
brake fluid (which I never used) = 5
Total = approx $241
Estimate from dealer $700 + tax
Savings = $450
And got a few new tools in the process
So after this I will start the actual description so I do it again in a few weeks.
Old 06-02-2012, 07:44 PM
dgjks6's Avatar
This is going to be very basic
Tools needed:
1 - jack
2 - jack stand
3 - wrench for removal of lug nuts
4 - 13mm socket on 3/8 drive socket
5 - T50 Star socket (6 point thing like a Torx, got it at autozone)
6 - 21mm socket on 1/2 drive wrench
7 - 6 mm allen wrench
8 - screwdriver - flat blade
9 - hammer
I will explaion how to use each one step by step
Also a bunch of towels and some brake cleaner and a pair of gloves.
To do it correctly you also need two torque wrenchs, on that goes up to at least 200 ft/lbs, and a smaller one that you can measure 15 ft lbs with.
Step 1
Remove plastic caps over lug nuts with nifty tool from the spare tire compartment. By the way, anyone ever look at the compact spare before. I just saw it for the first time. It is a sheet of rubber on a rim.
Step 2 loosen lug nuts
I used the nifty tool Audi provided in the spare kit
It is on the floor in front of the tire in the previous pic
Step 3 Jack up car and place on Jack Stand. I did one side at a time. Do not forget to place something behind the rear tire so there is no roll away.
Old 06-02-2012, 07:52 PM
dgjks6's Avatar
Step 4 borrow sons computer to install Audi repair manual from CD. Forgot to add this to cost. It was $24 and took 2 weeks to get here from California. It has info for all Audis. It has info on changing brake pads and removing calipers, but not rotors. I think according to Audi you have to remove the caliper - meaning take it off and disconnect from the brake lines, then I assume remove the rotor.
Warning....
I did not do it this way. I jest moved the caliper out of the way. I did not want to have to bleed the brakes. Next time I may give this a try.
The manual also gave all the torque specs needed for all the bolts.
So after that disclaimer, lets change some brakes
Old 06-02-2012, 08:00 PM
dgjks6's Avatar
Step 5
Disconnect wear sensor. The bottom tab comes out and it slides down
Step 6
Remove cap from bleeder valve. You need to do this so you can get the wire out. They use the bleeder cap to secure the wire. I just used a pair of pliers to pull it off
Step 7
remove nut from bolt that secures pads. It is 13mm and not very tight
Step 8
This is the first place I hit a glitch. You need to pound out the pin while pushing on the retainer clip. Since I was replacing everything I just pounded it out. I wouls recommend cleaning the bolf really good with brake cleaner becasue the dust makes it very tough to get the bolt through.
More to come, wife just brought home dinner
Old 06-02-2012, 09:43 PM
dgjks6's Avatar
Step 9
After the pin is out the retainer comes off. You can see it off in the last pic. The next step is to pull the pads out. You can do a google searchand find out how to get the pads out. I did not take a pic. What I did, since I was putting in new pads and rotors was use the screwdrive to pry them out. They came out easy
Step 10
This is the probably not how Audi recommends doing it step. The Brake line is solid near the caliper, so unlike all the pads/rotors I have changed in the past, I usually unbolt the caliper and hang it up while I switch out the rotor, but wuth the solid brake line you can't so this.
Option 1 - like Audi recommends, remove the brake line from the caliper and then recommect and bleed later
Option 2 - my improvised way. In the pic below you see the caliper without the pads in. See the white arrow?
Look behind it and you will see this allen screw (6mm)
You need a flashlight to see it, but when you remove it, the entire brake line becomes free enough to maove around a little.
Step 11
Remove caliper bolts
They are tightened to 200ft/lbs, which is a lot, so I need a little extra leverage
Old 06-02-2012, 09:52 PM
dgjks6's Avatar
Step 12
Remove the T50 Star bolt
Now the rotor comes off and you are done. The left rotor fell off after I took this bolt out. The right side needed a little persuasion. I talked nicley to it for a while and this didn't work, so I got out a hammer and convinced it to come off.
There. 12 easy steps. Putting it back together is the reverse.
Old 07-21-2012, 02:40 AM
mj-tj-aj's Avatar
Great post, how is sensor installed. I heard that rear pad rotors installation is tricky. Have you installed rear yet?
Quick Reply: Replace Q7 front rotors and pads
