02 Roadster - ESP and ABS Error Lights
Twice, my ESP and ABS Lights came on (at the same time) and stayed on until I stopped, turned off the vehicle and restarted. At that point, the lights stayed off for the remainder of the drive.
I took it to the dealership and although I'm told a historical record of codes is saved in the car computer, the lights being on did not generate any codes.
So, I asked these questions (with answers in quotes):
1. Is the vehicle safe to drive? "Yes and your ABS brakes work as long as the lights are off. When on, I have brakes but not anti-lock brakes."
2. What do I do now? "Try to catch when the light comes on. Did it occur around a sharp turn as that may cause the sensor to kick off. If possible, bring it in when the lights are on."
3. Is this indicative a failing instrument cluster? "Potentially."
I don't feel these are solid answers to the error lights problem.
Anybody have experience with this? Is this vehicle unsafe to drive?
Thanks for your help!
Last edited by Audictd; May 6, 2011 at 03:24 PM. Reason: Title clarification of specific vehicle
The car finally coded and the ABS module needs replaced. They did; however, reset it and considering it was not staying on, we are hoping it will stay off.
The replacement part is around $800 USED!
What is the MAF that you are referring to?
Thanks for your response!
The Mass Air Flow (MAF) sensor measures the amount of air flowing into the engine. I had the same lights + the check engine pop on & off randomly. Gimped it along by cleaning MAF but finally replaced it and lights went away permanently. The MAF can cause a variety of issues that don't seem air flow related but you usually get a code. I would get p1138 sometimes but not others (?) Good luck!
Mike Mulligan
Nov 5, 2013 06:06 PM
