1999 AUdi TT 1.8lt with issues help!!!!
Old Nov 14, 2007 | 11:08 PM
SLYTT's Avatar
Default 1999 AUdi TT 1.8lt with issues help!!!!
Hey guys need some advice about problems that my Audi TT Quattro with the 1.8tt 225hp
Hust brought the car 2 weeks ago and starting to regret it.
First Problem was driving to work today in the morning stoped at the traffic lights and noticed a beep beep looked down to see the oil pressure light, as soon as i took off it stopped, then i pulled into gas station checked oil level (which was fine then left) there was no more light for the rest of the trip which was stop start traffic. as soon as the car is going the light goes away.
ok next problem which is a bitch is after picking up the car from another state and driving it back (which was a 10 hour drive) i turned off the climate control off to save fuel started to rain 6 hours later tried to turn it back on and nothing, it wont switch on the little light in the handle wont light up and the climate control screen is dead, also noticed the temp reading that is in the middle of the cluster is blank in the middle where it would usually show the temp outside.
anyone with any info that can help would be mad
Thanks all
Old Nov 14, 2007 | 11:31 PM
cincyTT's Avatar
I'm make believe
Default RE: 1999 AUdi TT 1.8lt with issues help!!!!
First if you have a 99/00, you dont have a 225.
Sounds like you got a car with some gremlins. The cluster seems F'ed and is very costly to replace. Im not sure about the climate control stuff, but i have heard about the oil problem before. Ill have to go look that back up to find the fix.
Old Nov 15, 2007 | 12:08 AM
Murderface's Avatar
Climate control sounds like a simple fuse if the whole thing's dead.
Old Nov 15, 2007 | 11:58 AM
.clipse's Avatar
SoCal Crew Member
i've been driving with that oil pressure needle drop + led monitor flashing for quite some time. stupid gremlins
diggy84
Sep 10, 2014 11:45 PM
dark stranger
Feb 22, 2012 04:29 PM
pcguywilson
Jan 20, 2011 10:30 PM
jessicak
Apr 11, 2007 05:44 PM
glock40
Apr 9, 2007 10:37 PM
