2001 Horsepower guesstimate?
Subscribe
Nov 2, 2008 | 10:47 PM
First off: I know a Dyno run would tell me but I'm just trying to get a ballpark number.
What would you think a 225 TT with these mods be pushing?
2001 225 TT Quattro (K03s turbo):
REVO Stage 2 File
Modshack TTDA/****
Forge Splitter
42 Draft Designs High Flow Cat & 3" Downpipe
Milltek Exhaust
Reply
Nov 2, 2008 | 10:54 PM
first of all, you have a ko4 if you have a 225. You are looking at about 200awhp and maybe 240awtq
Reply
well unless u downgraded i dont think you are running k03 most likely a k04-20
Reply
Nov 2, 2008 | 10:57 PM
what do you have from osir? clear corners?
Reply
Nov 2, 2008 | 11:01 PM
OSIR Carbon Fiber Rear Valence
I was told at a local shop that the turbo in the 225 is a K03s because it has a larger housing thatn the K03 (like in the 180TT) but some of the K04 internals...
Still... guesstimates?
cincyTT - 200 awhp stock? or with those modifications...
Reply
Nov 2, 2008 | 11:02 PM
Well you need to find a new shop since they are completly WRONG!!! Please read the FAQ above.
And thats with those mods. It depends on the dyno, because they have dynoed in the 190awhp range
Reply
Nov 2, 2008 | 11:05 PM
i would not trust that shop to do another repair on the car, it is def a ko4-20 trust me mine just got replaced. I think ko3s were put int glis.
K03s and K04 use same size compressor wheel.
K03s has slightly smaller turbine wheel/housing (not sure which one, if not both) than the K04
Reply
Nov 2, 2008 | 11:09 PM
im clueless to my car..
Reply
Nov 2, 2008 | 11:13 PM
so when revo technik website says a chip makes a TT go to 260 HP. what is actually being told...?
i still have some issues differentiating bhp vs whp
Reply
Nov 2, 2008 | 11:17 PM
That is what the FAQ is for, PLEASE READ IT!!
Quote: i would not trust that shop to do another repair on the car, it is def a ko4-20 trust me mine just got replaced. I think ko3s were put int glis.
Completely false.
The ko3 is in the ATC 180's and AWD VW's. It is an 11 blade compressor wheel which is rated to 195hp.
The ko3s is is all the late 01+ VW/Audi cars. The only difference is that it uses a more efficient 8 blade design compared to the 11blade which makes it rated 210hp. The dimensions of the wheels are exactly the same.
The ko4-001 is basically the same as a ko3s but has a 1-2mm larger turbine wheel which makes it rated to 215hp.
The ko4-20/22/23 all have larger compressor and turbine wheels than the above. This is why it makes more power and actually hold the power closer to redline.
Reply
