2001 Horsepower guesstimate?
Old Nov 2, 2008 | 11:20 PM
cincyTT's Avatar
I'm make believe
Originally Posted by bvnguyen516
so when revo technik website says a chip makes a TT go to 260 HP. what is actually being told...?
i still have some issues differentiating bhp vs whp
The chip takes if for 225hp to 260hp or BHP which is brake hp or hp on an engine dyno aka crank hp.
When you dyno your car, the dyno reads whp which takes account for the powertrain, this is why these numbers are lower. A 2wd car will lose 12-15% and an awd car will lose ~20%.
Old Nov 3, 2008 | 12:32 AM
bvnguyen516's Avatar
Originally Posted by cincyTT
That is what the FAQ is for, PLEASE READ IT!!
Completely false.
The ko3 is in the ATC 180's and AWD VW's. It is an 11 blade compressor wheel which is rated to 195hp.
The ko3s is is all the late 01+ VW/Audi cars. The only difference is that it uses a more efficient 8 blade design compared to the 11blade which makes it rated 210hp. The dimensions of the wheels are exactly the same.
The ko4-001 is basically the same as a ko3s but has a 1-2mm larger turbine wheel which makes it rated to 215hp.
The ko4-20/22/23 all have larger compressor and turbine wheels than the above. This is why it makes more power and actually hold the power closer to redline.
when you say the k03s is in al the late 01+ audi/vw you mean all others aside the 225 TT?
Old Nov 3, 2008 | 11:06 AM
cincyTT's Avatar
I'm make believe
YES, all 150/180hp 1.8t models
Old Nov 3, 2008 | 12:55 PM
jhsoccerodp's Avatar
Im sorry I Had gotten my info off of here. Its like telephone, when one person tells something wrong, and another person finds the info and figures since they havent been correct it must be true.
http://www.vwfixx.com/forums/index.php?showtopic=40883
Old Nov 3, 2008 | 02:08 PM
TurboTT920's Avatar
My dyno runs yielded about what cincy said running off the n75 except my wtq was higher...closer to 290wtq and 200whp...with the n75 out and a mbc in the tq stayed pretty much the same but gained in the hp...similar mods to the op
Old Nov 3, 2008 | 02:19 PM
cincyTT's Avatar
I'm make believe
Those people are talking about the ko4-001 which is completely different than the ko4-20/22/23 that the 225 runs. W/o giving the last numbers, people get confused.
kevin.eversole12
Jan 27, 2012 06:03 PM
lewis42189
B7 Models
Oct 29, 2010 07:24 PM
RoboRabbit
Nov 13, 2008 10:58 PM
haveaseat
Feb 27, 2007 09:26 PM
Ferny
Nov 9, 2006 03:30 AM
