2001 TT 225 - Creaking Suspension (Conclusions)!
Old May 31, 2007 | 09:52 AM
  #21
diehlryan's Avatar
Default RE: 2001 TT 225 - Creaking Suspension (Conclusions)!
ORIGINAL: MeanAudiA6
its the front sway bar bushings take a look at them and see what they look like....also make sure the bolts are still good and not sticking out a little as this will cause the creak(meaning the bushing is bad)
thats what I said but no one paid any attention!!!
[sm=headbang.gif][sm=headbang.gif]
Old May 31, 2007 | 10:00 AM
  #22
superreverb's Avatar
Ryan,
But haven't ppl replaced the sway bar bushings and still heard the creaking,, IIRC?
I've got my TT in the shop today and pointed him in that direction..
Thanks,
Shamus
Old May 31, 2007 | 10:14 AM
  #23
diehlryan's Avatar
I'd think strust bushing/bearing then.
Old Jun 1, 2007 | 10:52 PM
  #24
TTRU's Avatar
Most likely the front sway - there is a plastic sleeve between the sway and the bushing thatworks it's way loose. Mine looked like this. (edit-can't get pics toshow upso here are links - duh)
http://images111.fotki.com/v749/phot...jpg?1159628484
There is a TSB which calls for replacement of theswaybar and bushings.
http://images23.fotki.com/v867/photo...jpg?1180752566
Hope that helps!
Old Jun 2, 2007 | 09:47 AM
  #25
XCLR8TT's Avatar
To post pics... Just click on this button in the tool bar.
The suspension creak in the front is normally the plastic sway bar bushings as you mentioned. In the rear the sway bar bushings don't have the same plastic piece, but they still wear out and squeak.
The suspension clunk is most likely the strut bearing/bushing gone bad. You can pick up a replacement set at ECS tuning for around $30.
Old Jun 12, 2007 | 04:51 PM
  #26
mitch187's Avatar
Hey.I found it really funny that you compared your sqeaking sound to an old bed... Mine does the same and I was wondering if you had a solution to the problem. The dealership says that there is nothing they can do because it is an aftermarket suspension... and being the options/oppotunity guy I am, I feel that there is a solution.
I found this recenty and wondered if it made sense to you...
http://forums.audiworld.com/tt/msgs/776463.phtml
The squeaking sound is coming from the rear passenger side... dealer says it's the shock rubbing on something...
Please, any help is appreciated.
Mitch
Old Jun 16, 2013 | 02:28 AM
  #27
shorne's Avatar
Today I discovered that the creaking front suspension sound on my 2001 Audi TT 225 is coming from the suspension level sensor (this is the small mechanical linkage that is attached to the driver's side suspension "wishbone"). I tried spraying it with some silicon lubricant which stopped it for a few minutes but it's coming back. I'm thinking I need to put some grease of some sort on it?
Anyways, I'm thankful that it's not some sort of more expensive suspension problem! :-)
--Steve
james_autos
Oct 23, 2011 09:46 AM
rplets15
Jun 27, 2011 12:58 PM
superfly78209
May 16, 2010 08:28 PM
kingfisher
Mar 22, 2009 10:58 PM
jk944s
Oct 27, 2008 12:56 PM
