2002 TT Will not Start After Driving
Old Nov 6, 2016 | 03:31 AM
Krank's Avatar
Default 2002 TT Will not Start After Driving
6 speed manual 1.8L TT2002.
I drive for a little while (say 40kms) and then stop for a little while (say 5-10 mins), then it does not start.
I have electrics ON and a good well charged battery and a full tank of fuel.
The only method I can start it is by cranking a fair bit with the key and pumping the accelerator pedal.
It cranks over just fine but will not fire up.
Please tell me why this is happening and how I can rectify this problem.
Krank
Old Dec 7, 2016 | 09:25 PM
npcullen's Avatar
I'm having a similar issue on '02 TT 1.8 6MT roadster, car died while driving. Cranks no fire. After 20-30 minutes restarted. died again five minutes later (fortunately on our lane), OBD service tool wouldn't connect, 20-30 minutes later, service tool connected, P0322 code had logged, started on next crank attempt. Have not had a chance to troubleshoot further.
Old Feb 24, 2017 | 04:57 PM
Derek Moore's Avatar
Default Yeah
mine is doing it as well. 03 model 1.8 auto trans. Also, once it starts doing that, if i press the pedal all they to the floor while driving when i get to high rpms it will lose power, cut out n choke like its starving for fuel or flooding.
Old Feb 24, 2017 | 06:50 PM
npcullen's Avatar
I replaced the crank timing sensor and it has been running fine since. Not sure why the service tool wouldn't connect- any correlation between the timing sensor and datalink.
Old Feb 24, 2017 | 11:28 PM
Default Hmmm
Why would the crank timing sensor work fine when the engine's cold the work intermittenly when hot? It seems like a coolant temp or engine speed or mass air flow sensor thing to me. But, if i knew it all i wouldnt be here looking for answers, would i? Congrats.
Old Feb 26, 2017 | 07:44 PM
Default Found mine
I put a coolant temp sensor on mine ($13) and its been fine since. Drove 60+ miles afterward and no issues. I have a camry that did that too. Ran fine when cold then would shut off at stoplights n stuff after the motor got hot.
muccamoofrog
Feb 24, 2017 11:32 PM
s.Ilton
Feb 17, 2013 11:40 PM
dsabra11
May 14, 2011 08:51 PM
jsethwerner225
Jun 26, 2010 11:04 PM
jjmorgan71
Jun 29, 2006 10:08 PM
