2003 Transmission
Old Nov 3, 2010 | 11:05 PM
sjf's Avatar
sjf
Default 2003 Transmission
Hi everyone, a couple of questions about my car:
2003 225HP 6SP (manual) TT Quattro.
It was running fine. I parked it and came back a few minutes later and found that I was unable to get in to 1st and 2nd gear. Reverse, and 3-6 all worked fine.
I tried adjusting the shift linkage, but that made no difference.
Is this likely to require a new transmission ?
Could it merely be an issue with the synchro sleeve ?
If I do need a new transmission, is there any possibility of swapping between the codes. For instance, I have an "FMN" would a "DQB" be a direct replacement.
Financially, this couldn't have happened at a worse time. I'd like to take the least expensive option.
Thanks in anticipation. Cheers
JPAT9
Dec 17, 2012 07:54 AM
dave944
Mar 10, 2012 06:33 PM
Mcsoccer9
Jan 19, 2012 11:02 AM
Obin99208
Jun 7, 2011 08:26 PM
shanpai
Apr 16, 2011 01:10 PM
