3.2 DSG engine Vibration at 1500 rpms
Old Apr 18, 2008 | 10:47 AM
jayhettich's Avatar
Default 3.2 DSG engine Vibration at 1500 rpms
When the car is in park and i rev the engine its smooth as glass before 1500 and after 1500... but vibrates like hell AT 1500 rpms.... my dealer is giving me the "thoes cars do that" brush off... so im asking... Does everyone elses do that???????? I dont notice it at all when its in gear... just in park or neutral...
Old Apr 18, 2008 | 11:28 AM
moeron7's Avatar
Default RE: 3.2 DSG engine Vibration at 1500 rpms
There arent many 3.2 owners in this forum if any so i'm not sure you will get much help. Anyways why would you rev in park or neutral? How bad of a vibration is it?
Old Apr 18, 2008 | 12:52 PM
jayhettich's Avatar
I just discovered it when i bought the car and have never known an engine to do that. It vibrates enough that you can feel it through the steering wheel and seat... it shakes the car.My concern is that there is an underlying cause that could end up damaging the engine later on.
Old Apr 18, 2008 | 02:19 PM
.clipse's Avatar
SoCal Crew Member
motor mount?
Old Apr 18, 2008 | 03:13 PM
theTTkid's Avatar
motor mount?
i had 2 blown mounts and all i got was a little clank, no vibration.
then again i dont have the 3.2
Old Apr 18, 2008 | 04:06 PM
Audi858's Avatar
ORIGINAL: theTTkid
motor mount?
Of course you would get vibration from bad motor mounts that goes for any care. Pop your hood and have some one stand outside and look at the engine or you. Then have someone or you inside the car and put it in drive. Put your E-brake up all the way and give it gas also do this in reverse. If the motor is shifting alot then its your motor mounts.
Old Jul 17, 2013 | 07:17 PM
RichardRutenberg's Avatar
Default solution
what turned out to be the cause of the vibrations?
diablo9861
Nov 23, 2009 12:21 PM
Codyf
Oct 19, 2008 06:57 PM
Mikesa6
Aug 19, 2008 04:09 AM
k1.8t
Aug 15, 2007 03:20 PM
