3 inch catback and coil overs
Old Nov 12, 2008 | 04:52 PM
meezy33's Avatar
Default 3 inch catback and coil overs
So I went to my exhaust shop today to see what they would quote me to build my custom catback with the borla xr-1. They told me to go 2.5 inch because the 3 inch would rub if I lowered the car with coils which im planning on doing in december. Anyone have any input on this i really want a 3 inch exhaust not 2.5 due to future plans with the 50 trim .
Old Nov 12, 2008 | 05:00 PM
WishIWasRWD's Avatar
uhhhhh... .5 inch will make you rub?
I think he just doesn't have, or can't bend 3" piping.
Old Nov 12, 2008 | 05:06 PM
cincyTT's Avatar
I'm make believe
you can make a 3" work. Plenty of low *** cars have them. They are just worried about clearing the rear frame section.
Old Nov 12, 2008 | 05:23 PM
meezy33's Avatar
I thought the same thing that he just couldnt bend 3 inch piping but it turns out he could so I'm not really sure why he said that. but thanks for the quick replys I'm gonna go ahead and get the 3 inch done
Old Nov 12, 2008 | 05:26 PM
warranty225cpe's Avatar
yeah dude, that's bullshit. If your close to south Florida, my boy will make you a sick cat back set up for 2 or 300$. Dude is a magician with a welder. And his prices are more than reasonable. You would have to buy your own muffler tho.
Old Nov 12, 2008 | 06:24 PM
moeron7's Avatar
We need sound clips once installed!!
Old Nov 12, 2008 | 07:34 PM
bvnguyen516's Avatar
i have 3" 42DD DP + Bilstein PSS9. I lowered a little bit more than a inch in front and back. Still have lots of room... I would have to like jump a ramp or steep incline to rub to hit it...
Old Nov 12, 2008 | 07:48 PM
zero388's Avatar
Here is a pic of my custom 3" catback on my FWD TT. You will probably end up with some vibrations, especially if you go BT, but they will mainly be from the DP. It is easy to make the catback not hit the rear subframe.
Old Nov 12, 2008 | 08:02 PM
how bad are the vibrations from a DP? if i have any issues, im not likely to keep a DP.
Old Nov 12, 2008 | 08:09 PM
zero388's Avatar
they are not that bad at all only really noticeable at idle, the vibrations I am experiencing is partly because I have the kinetic exhaust manifold which moves the DP a little bit. but I doubt you will have the issues I have because you have a 225Q and I have a fwd.
