3 simple questions?
Old Jul 26, 2007 | 06:58 PM
andrei's Avatar
Default 3 simple questions?
1.what should the vacuum level be for a 225? I have a boost gauge that shows 20-21 in the vacuum side...is that ok?...
2.and a stupid question, why do we get vacuum,I knowI can search and find out, just like anything in this world, I'm lazy though... hope you guyscanshare some knowledge...
3.if the FPR doesn't have anything connected( no hose) is that bad?... when i installed my gauge the hose disconnected from too much pressure, on the freeway (gauge showing 0)...
hope one of you has the patience to read and answer my stupid questions... thank
Old Jul 26, 2007 | 07:12 PM
moeron7's Avatar
Default RE: 3 simple questions?
ORIGINAL: andrei
1.what should the vacuum level be for a 225? I have a boost gauge that shows 20-21 in the vacuum side...is that ok?... My hg is around 15-17. up to 20 if my AC is on
2.and a stupid question, why do we get vacuum,I knowI can search and find out, just like anything in this world, I'm lazy though... hope you guyscanshare some knowledge...No clue
3.if the FPR doesn't have anything connected( no hose) is that bad?... when i installed my gauge the hose disconnected from too much pressure, on the freeway (gauge showing 0)...You should have the guage hose connected to it. Thats why you are reading 0. You should find the hose and put it back on and tighten with something.
Old Jul 26, 2007 | 07:18 PM
cincyTT's Avatar
I'm make believe
The FPR should have a direct vacuum source from the manifold. If you dont have that attached, bad things may/will happen. Dont drive it until you get that reattached.
Old Jul 27, 2007 | 08:46 AM
diehlryan's Avatar
ORIGINAL: moeron7
ORIGINAL: andrei
Hey moeron - hows the credit card bill coming along that you bought all those mods with?
Old Jul 27, 2007 | 09:13 AM
achTTung's Avatar
Your engine is an air pump, draws air in, burns it, pushes it out, but between the engine itself and the air box, theres a thing called a throttle body. In it isa plate that closes off the intake so the engine can't get air. Put a restriction on the path to an air pump, and you create vacuum. Thats why you pull vac when you're not on the throttle, and why it dissappears when you rev the car (throttle plate is open)
Old Jul 27, 2007 | 10:31 AM
moeron7's Avatar
ORIGINAL: diehlryan
You dont wanna know. And something else that sucks is I need a new clutch. So you know what that means....
adam044
Feb 20, 2014 08:31 AM
G2SSM
Sep 8, 2013 08:53 PM
Lmal355
Jan 10, 2011 12:14 PM
@udikid
Jan 30, 2009 11:38 PM
Blue_S4
Oct 13, 2007 10:57 AM
