300bhp in a 225 Quattro
Old Dec 14, 2006 | 11:45 AM
RAUDITT's Avatar
Default 300bhp in a 225 Quattro
Is it possible to make 300hp at the wheels without a Major upgrade such as Stage III turbo? Someone mentioned an ATP eliminator kit is a good start. What do you guys think?
Old Dec 14, 2006 | 11:55 AM
BlackRaptor's Avatar
Default RE: 300bhp in a 225 Quattro
Well the ARP chip tune says 263hp/267lb-ft
So if you added Borla Exhuast which i would guess you could get an extra 10hp out of.
Neuspeed intake which is another 10ish if your luck.
Thats 283hp
If you did a big FMIC and could get your temps down i would bet you could get into the 290HP range.
But i've never seen all this stuff on the dyno before.
Old Dec 14, 2006 | 12:21 PM
RAUDITT's Avatar
ORIGINAL: BlackRaptor
Thats 283hp
Isnt the APR spec 263 to the flywheel? I didn't think that was to the wheels. My shop here told me with the APR tune (which I had done on Tuesday), i'm prolly getting around 190whp.
Old Dec 14, 2006 | 01:27 PM
XCLR8TT's Avatar
ORIGINAL: RAUDITT
The ATP eliminator is a big turbo upgrade.
Old Dec 14, 2006 | 03:14 PM
225tt's Avatar
I hope to dyno my car soon, when i get the Forge FMIC and I am thinking of putting DEI's Cry02 system in my car, hopefully that with a few upgrades I hope to hit 300whp. Hopefully... but dyno results from what I have so far are soon to come...
Old Dec 14, 2006 | 03:23 PM
XCLR8TT's Avatar
ORIGINAL: 225tt
No way are you going to hit 300 whp without a big turbo upgrade. Remember your 225 is flywheel hp not at the wheels. There is about a 20% loss through the AWD system down to the wheels.
Old Dec 14, 2006 | 03:37 PM
RAUDITT's Avatar
ORIGINAL: XCLR8TT
ORIGINAL: 225tt
So which BT should I go with? There are a couple different ATP eliminator kits. One is rated at 300, the other at 350, and not much of a price difference?
225tt's Avatar
So in theory if you can get to 360 crank hp then you will be at 300whp? 20% loss? That sounds kind of high, is there any place where this can be looked up with dynos and numbers?
Old Dec 14, 2006 | 03:47 PM
XCLR8TT's Avatar
ORIGINAL: 225tt
There are numerous examples out there, but here is one from ProjectTT at VWVortex.
Old Dec 14, 2006 | 04:29 PM
225tt's Avatar
Cool thanks, what do you think you would need your TT to be at as far as HP numbers to run 12.0 in the 1/4mile?
