3rd Gear Better After Gear Oil Change
Old Aug 12, 2008 | 12:27 PM
alan93's Avatar
Default 3rd Gear Better After Gear Oil Change
I was getting some grinding going into third at various times. Mostly when down shifting quickly from a higher gear to take a corner or what ever.
Also got this coming up from 2nd sometimes.
However, It would be ok if I gave it some time after pushing in clutch.
Changed gear oil because not sure when it was done last. The place that did said that the old oil didn't look to bad and no shavings were found.
Put in Royal Purple.
Seems smoother all the way around.
They forgot to drain bevel box but I hope its not a biggie.
Is 3rd gear some sort of anomaly on this car?
Old Aug 12, 2008 | 12:43 PM
cincyTT's Avatar
I'm make believe
its usually the 1-2 shift that is the biggest problem. You have been around long enough im sure you have heard about the syncos not liking older oil
Old Aug 12, 2008 | 05:53 PM
beachchair's Avatar
How does the Royal Purple compare with Red Line?
Old Aug 12, 2008 | 06:40 PM
joshuo's Avatar
does anyone now of a good source for the redline oil?
Old Aug 12, 2008 | 06:58 PM
cincyTT's Avatar
I'm make believe
You should be able to find both at the local parts store, if not, ecstuning sells it.
Old Aug 12, 2008 | 09:11 PM
alan93's Avatar
older = ?
I wasn't sure when it was done last since I only had the car for 10k miles.
Haven't heard about 1 & 2 but did a search for 3rd and found a lot of the same thing on that
Old Aug 12, 2008 | 09:14 PM
.clipse's Avatar
SoCal Crew Member
^ 1st to 2nd grind is notorious on the TT.
Old Aug 13, 2008 | 06:03 PM
achTTung's Avatar
I've always heard 3rd, not 1-2, and can confirm with my car, and that a gear oil change will help a ton.
Believe it was the bevel box that had the magnetic drain plug. I promise you it's covered in filings. The shifting problem is related to the syncros, which are brass, aka, non magnetic, but you'll find steel bits, and probably a little brass in/around the bevel box.
I've always bought my redline oil from summit.
cristian duca
Nov 14, 2011 09:13 AM
Kev Quattro Kibble
Jul 1, 2011 10:37 PM
uzi1314
Oct 28, 2008 08:36 PM
