630cc file
Old Apr 8, 2008 | 07:40 PM
Audi858's Avatar
Default 630cc file
Is it a bad idea to run 550cc injectors on a 630CC ecu file?
Old Apr 8, 2008 | 09:24 PM
MeanAudiA6's Avatar
Default RE: 630cc file
i can see that causing major problems since that software is made for the 630 injectors
Old Apr 10, 2008 | 12:04 PM
cincyTT's Avatar
I'm make believe
550cc @4bar = 630. There are a handful of people running them. You may need to adjust idle fueling however.
Old Apr 10, 2008 | 02:00 PM
DurTTy's Avatar
on that note... is it ok to run a 550 CC file with 630CC injectors?
Old Apr 10, 2008 | 03:57 PM
cincyTT's Avatar
I'm make believe
There are people doing that also. Again, you will have to play with fuel trims most likely. The only 550cc file i know of is from Revo. Not the best, better off spending the extra $100-200 on a 630cc eurodyne/tapp tune
Old Apr 10, 2008 | 04:03 PM
MeanAudiA6's Avatar
he should then be running a 4bar FPR correct? lol
Old Apr 10, 2008 | 04:30 PM
cincyTT's Avatar
I'm make believe
550cc on the 630 file yes
630cc on the 550 file no
chris120391
Jan 21, 2011 02:16 PM
preyash
Dec 8, 2008 10:32 PM
Greg@SSPTuning
Dec 5, 2008 02:02 AM
Audi858
May 23, 2008 05:03 PM
xxipsxx
May 31, 2007 11:01 PM
