70mm Big Bore Throttle Body - GRAMS - 60% more flow
Old 04-02-2018, 01:03 PM
ECS Tuning's Avatar
Sponsor
Default 70mm Big Bore Throttle Body - GRAMS - 60% more flow
Grams 70mm Throttle Body for the Audi/VW 2.0T
Ditch the restrictive factory 57mm throttle body in your Audi for a Grams 70mm Big Bore electronic throttle body!
This upgraded big bore throttle body is a plug-and-play replacement that improves your engine air intake and includes everything you need to make the swap, no tuning required!
The Grams 70mm Electronic Throttle Body for VW/Audi is the perfect upgrade for the restrictive and trouble-prone factory 57 mm VW/Audi throttle body.
The Grams throttle body is a Plug-n-Play direct OEM replacement that doesn’t require wiring or mounting adapters.
These units are not remanufactured. Each throttle body includes all new components including a CNC machined billet 6061-T6 aluminum housing with a precision-honed oversized bore, a high-torque servo motor, and a proprietary Non-Contact Hall Effect TPS sensor.
To ensure the best performance, throttle response and driveability, each TPS sensor is calibrated to meet the specific requirements of the vehicles engine management system.
The Grams electronic throttle body is the perfect upgrade for both modified and stock engines with increased airflow and reliability demands.
Click HERE for your Audi/VW 2.0T Grams Performance 70mm Throttle Body Upgrade
kraylon
09-02-2009 09:32 PM
joelml
04-22-2008 07:10 PM
anmagro
01-24-2008 08:40 PM
brewskie
03-02-2003 12:22 PM
Quick Reply: 70mm Big Bore Throttle Body - GRAMS - 60% more flow
